Rake Cheap Harley Rake?
/ Cheap Harley Rake? #11
Mark
Now that one worked perfectly! Thanks.
Very nice pulverizer. I have a few questions if you don't mind.
On your roller, did you weld a stub on the ends or use a continuous "axel"? What size axel stub did you use? I am assuming you used pillow block bearings of some sort on the end brackets, is this correct? Are they greasable or sealed?
On your roller ends, did you have the centers machined for your stub axels to eliminate ALL wobble, or can you get away with finding the center and drilling out with a drill and welding in the stubs?
micromike
/ Cheap Harley Rake? #12
<font color=blue>Now that one worked perfectly!</font color=blue> Strange. I did reduce the size from 800x600 to 640x480 this time, but that's all.
<font color=blue>On your roller, did you weld a stub on the ends or use a continuous "axel"?</font color=blue> Continuous axle. <font color=blue>What size axel stub did you use? </font color=blue> 1 1/4", not because I thought it was necessary for strength, but because that was the size the scrap dealer had for cheap. <font color=blue>I am assuming you used pillow block bearings of some sort on the end brackets, is this correct?</font color=blue> Yep. <font color=blue>Are they greasable or sealed?</font color=blue> Greasable.
<font color=blue>On your roller ends, did you have the centers machined for your stub axels to eliminate ALL wobble, or can you get away with finding the center and drilling out with a drill and welding in the stubs?</font color=blue> We just drilled them. It's not super easy, but it's doable without too much difficulty.
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
Topcat SSSCR72 (A60463)
Topcat SSSCR72...
2020 Deere 317G (A60462)
2020 Deere 317G...
2018 Chevrolet Cruze Passenger Car, VIN # 1G1BC5SM5J7145503 (A61165)
2018 Chevrolet...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
John Deere 4520 (A60462)
John Deere 4520...
