Cheap FEL cylinders keep bending
   / Cheap FEL cylinders keep bending #11
I don't care what bucket is on it somthing is wrong!!, them cyls should not be bending, there is a fault in the rods, undersized or not hardend properly, they look undersized to me, the older cb65 sub compacts bh had the same issue with the dipper cyl, new revised cyls were issued and problem was solved.
i agree, even pressure relief should be stopping them before allowing them to get to that point
   / Cheap FEL cylinders keep bending #12
Correct
   / Cheap FEL cylinders keep bending #13
I'm not going to argue about the quality of the cyl. rods, they aren't here for me to see in person, but I still say that bucket is on too small/lightly built tractor and I don't care what the brand is.
Those buckets put huge torque on a loader and should be on a larger sized tractor.
SR
   / Cheap FEL cylinders keep bending #14
SR
I will agree with that statement IF he had let go of the control stick and bounced it, if you watch the video to the end, you can see where he lets go of the downforce, why isn't the tractor going into pressure relief. that's my issue.
   / Cheap FEL cylinders keep bending #15
Oh so many things jumps out at me after seeing all the images…
Notice the holes… why are they unused?
When it should have these brackets in place like these…
Somebody screwed up at the dealership.
   / Cheap FEL cylinders keep bending #16
There SHOULDN’T be cylinders that look like that. It looks modified to “fit”.
that appears factory...
   / Cheap FEL cylinders keep bending #17
Buy a CTL and stop treating your tractor like one.
   / Cheap FEL cylinders keep bending #20
The combination of no triangulation brackets, fully extended cylinders, and large forces acting on the stump digger is a recipe for trouble.
That stump digger certainly looks it’s designed for skid steers.
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
JOHN DEERE 300 GALLON NITROGEN APPLICATOR (A52708)
JOHN DEERE 300...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
