Cheap FEL cylinders keep bending
/ Cheap FEL cylinders keep bending #41
Hitting mechanical stops before cylinder fully extended shouldn't cause this....infact you WANT the stops to be hit just shy of full extend.
I don't think so. Your cylinders should be able to travel freely and completely in both directions without hitting any solid stops. Otherwise you're constantly using your hydraulic system to stretch / stress metal rather than simply position your implement.
  • Good Post
Reactions: JWR
/ Cheap FEL cylinders keep bending #42
My view is that a hydraulic cylinder simply pushes 2 pins apart or pulls those 2 pins together, nothing more. If the cylinder rod buckles, it’s a sign that the rod is longer than it’s diameter supports, and/or that the extend pressure is excessive.
Cannot speak for this particular loader....but loaders arent new science. MOST manufactures use cylinders that can handle full hydraulic pressure even at full extent.
Its not about too much hydraulic pressure/force.
But rather when an outside force acts upon the cylinder......like back dragging with the loader curled down. There are literally dozens of posts on this forum of that exact same thing happening with only a stock bucket. now you add on a LONGER bucket and it is much easier to do.
If one were to take a hydraulic pressure gauge and TEE into the curl circuit....and replicate back dragging with the bucket dumped....you could easily see pressure spikes in excess of 5000 psi. Which is about double what that cylinder is ever designed for and double what the tractors hydraulics are capable of. I think THAT is the problem here.
/ Cheap FEL cylinders keep bending #43
/ Cheap FEL cylinders keep bending #44
You can easily test your theory.
Take one of your curl cylinders off the bucket and extend it fully. Measure it. Put it back on and dump the loader until it hits the stops. You will find the cylinder did NOT extend all the way.
On tractors, this is curl only. keeps you from blowing the gland cap out of the cylinder. Dumping a heavy load while raised (like dumping into a dump truck) the weight of the material in the bucket and the speed of dump when it comes to an abrupt stop, the piston inside the cylinder constantly hammering against the gland cap and trying to escape.....it wont take long and it will be free.
There is mechanical stress/stretch on the loader anytime the hydraulics are used. They are designed for it.
/ Cheap FEL cylinders keep bending #47
Pivots are missing according to parts diagram.
In my own quest to try and figure out if the loader was supposed to have those pivots, I too pulled up the parts diagram.
IMO, that photo is just a stock photo they use as a parts diagram for different loaders as well.
Notice the near side loader arm does NOT show those pivots, and there are NO part numbers assigned to those pivots either.
So that in combination of videos I found on masseys site, as well as all the other pictures of tractors for sale....I think its safe to say that the loader is assembled correctly....and that they just use this same main boom for different loader combinations, some of which "MAY" use the pivots.
That seems alot more reasonable to me than dozens of dealers assembling wrong and leaving parts out, including videos on masseys own website
/ Cheap FEL cylinders keep bending #48
It is cheaper and easier to eliminate the 4 link feature and extend the bucket cylinders while retaining the same boom for use (probably) on lower spec loaders.
Putting the boom part number in a 'where used' search may be helpful.
/ Cheap FEL cylinders keep bending #49
The issue is when the manufacturers decide to increase the rod length without increasing the rod diameter instead of increasing the length of the spacer welded on the back of the cylinder.
/ Cheap FEL cylinders keep bending #50
Yup. It is indeed poor engineering.
But the question is still whether it is acceptable.
As the current loader sits, with the rod extended in lieu of the linkages or lengthening the back of the cylinder.....is it still "enough" to handle the full column load.
Id really like to know:
1. The rod diameter
2. The length of the rod when fully extended (included the extension part)
3. The bore of the cylinder
4. The tractors operating pressure.
With the bore and operating pressure it is easy to calculate the force that the tractors hydraulics can exert on the cylinder
With the Rod diameter and Rod length, it is easy to calculate its buckling strength.
If its within spec....while not a great design...I think the MFG is covered and can chalk it up to operator error.
If it is NOT within spec....I think there is a great case to get massey or the dealer to eat the cost of replacing the cylinders.....then upgrade asap.
I believe the owner of the tractor mentioned on the AR15 site that they were 1.25" rod diameters.
With that rod diameter and rod lenght @:
16" = 17,670# column load
18" = 12,690 #
20" = 10780 #
24" = 8050 #
28" = 6240 #
30" = 5550 #
If the tractor is 2500psi:
50mm cylinder = 7680#
2" cylinder = 7853#
55mm cylinder = 9206#
2.25" cylinder = 9940#
60mm cylinder = 10,957#
2.5" cylinder = 12,271#
65mm cylinder = 12,858
Wish I had more info on that loader cylinder......
/ Cheap FEL cylinders keep bending #51
This has never happened on my Green tractor. This one probably assembled by a 'repeated 3rd grade student' with a cell phone in 1 hand and a pipe in the other.
/ Cheap FEL cylinders keep bending #52
Same boom is used on the FL2814 loader....which DOES use the linkages.
Lift cylinders are the same but the curl cylinders have a different part #.
If it were me....Id be pressing the dealer to order and install all of the parts pertaining to the linkage and the cylinders spec'd for the 2814 loader. Thats if its determined that their idea of lengthening the rod and it can no longer handle system pressure without buckling. Still yet to be determined if this is operator error.
/ Cheap FEL cylinders keep bending #53
Looks like the absence of the pivot linkages is probably what is causing the issue, hopefully you get it worked out real soon.
/ Cheap FEL cylinders keep bending #54
I know Massey sent some cylinders out with the wrong diameter cylinder.
This caused a few to get bent up, about a year or so ago and replaced under warranty.
Don't think there were many of them though and not sure if FEL or BH, think BH.
Check Cylinder part numbers just in case.
/ Cheap FEL cylinders keep bending #55
Whether the linkages are there or not shouldn't make a difference with regard to the cylinder bending.
The linkages removed should make the bucket curl back more, and dump less...that's all.
The parts diagram, even with the linkage shows a short cylinder with extensions on both rod and base.
Piss poor design....and honestly....I'd be questioning my purchase and looking to either a different model or different brand
Agreed the whole loader is a complete design fail starting with the lower arm section being too long. The cylinder and linkage is a complete hack job. The bucket quick attach plate also appears to fit poorly. If they can’t make a loader any better than that I’d question the rest of tractor. BUT even if the loader was correctly built putting a stump bucket on a tractor is still a bad idea.
/ Cheap FEL cylinders keep bending #56
Been following this because it was concerning since I own a massey, not as big as this one but still concerning. After someone else suggested that the rod was already bent I looked at the video again. This is a blow up of the rod at the 4 second mark on the video. This is just before the bucket makes contact with the ground. You can tell when the bucket contacts the ground because the pressure causes the FEL frame to move upward. I don't know what others think of this but that rod looks like it was already bent to me.
Edit: This was clarified either earlier and I missed it or after I posted. Yes the rod was already bent because the rods originally bent before the video and then the OP attempted to straighten them and then took the video. So there is no way of knowing what condition the rods were in before the original bending.
/ Cheap FEL cylinders keep bending #57
if you guys read what i wrote, the op is in the ar link. he said it bent simply pushing the joystick up, the tractor was not moving.
he then created the video to show it happening again, while not moving.
for those of you who keep think parts are missing. you may want to do a google image search. there are multiple pictures of various tractors with the same linkage. The op is not missing parts.
/ Cheap FEL cylinders keep bending #58
Thats simply when he noticed it. How much prying....and rocking the tractor back and forth....while focused on the stump and not the cylinders happened before the video was taken.
The rod is ALREADY compromised in the video. Thus the column ratings of that rod are out the window and its on has a fraction of the buckle strength it once had. So shooting the video.....yea it bends easily under the tractors own power.
What I did NOT hear/read is that these were bran new freshly installed cylinders that saw NO action prior to the video being shot....if that were the case....then yea thats a problem.
/ Cheap FEL cylinders keep bending #59
Ironic I cannot find ANYTHING on masseys site for the 2750/2760e.
But I did find this video on their website that can hopefully put to rest whether its missing parts or not.
The video....paused at both 0:24 and 3:39 both show a FLx2815 loader and it does NOT have the linkages.
As I have said before, some loaders have them, some dont. But regardless, the cylinders should NEVER be capable of column buckling under their own hydraulic force.
The ONLY think that should cause column buckling is an outside force GREATER than the hydraulic force they are capable of.
And example of that is with the loader dumped all the way and attempting to back drag with the cutting edge. We have all seen that on here a time or two. But it should NEVER happen under the loaders own power.
I have to wonder though.....in the video the OP posted, if the cylinders werent already bent from said activity. The LONGER bucket would compound the forces if used while dumped and backdragging. Requiring less effort/traction to make the cylinders bend. It dont matter if its a stock bucket, or a 4' stump bucket, or hell a 10' long bucket....it should NEVER happen under its own hydraulic power. But it DOES matter if you are using tractive power, and the bigger (longer) the bucket the easier it happens.
So if these cylinders in that video were already compromised.....THEN and ONLY THEN can I see the tractor being able to do that with hydraulic power alone.
Is the tractor owner a member here? CoTHg is this your tractor or someone you know? Can you direct him here....on a tractor forum where he may get more help than on a AR15 forum?
The following are the screenshots of the video on massey's own website showing no linkages or missing parts
In the video, it looks like that the loader with the pivots is used for pushing and loader type work, and the pivotless one is used for lifting only. Even though you see the pivotless one with a bucket, its never shown actually being used to shovel.
/ Cheap FEL cylinders keep bending #60
There is only so much a cylinder rod will take. If the "scoop" had only been used to lift at the tip I doubt you would have had an issue. Pushing down on the tip exerts a lot of force on the rod. Imagine pulling up on the front edge of the standard bucket and the hydraulic pressure created within the cylinder. Now imagine putting a 5' cheater bar on the bucket and lifting up and see how much hydraulic pressure it creates trying to compress the cylinder.
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A60430)
UNUSED SDLANCH...
2008 Volvo XC90 AWD SUV (A59231)
2008 Volvo XC90...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
