Eric_Phillips
Platinum Member
I have a mower with a hydrostatic drive. The manual says to change the oil every 500hrs. I talked to a dealer and they said they never change the oil just the filter. They also mentioned that they didn't know how you would get the oil out. Is there some trick to gettting the oil out of a hysrostatic drive unit? There are some hose connections that look to be at the lowest point of the system. Couldn't I just take one of those connections off to drain the oil? The manual is no help in this matter. This is a Ferris Procut32 if that helps anyone.
