Snowblower Changing from loader to front snowblower
/ Changing from loader to front snowblower #1
Anonymous Poster
Epic Contributor
I would like to hear from anyone who exchanges their loader for a front snowblower in winter. Which tractor in the 20-35 hp range is the easiest and quickest to make this exchange. I'm colorblind so I am interested in hearing from Deere, Kubota and Boomer owners. Thanks to all who respond.
/ Changing from loader to front snowblower #2
It is a very quick process to switch either way with John Deere compacts assuming the loader and snowblower are also JD. Loader installation/removal takes maybe 2-3 minutes. To install the snowblower, a small bracket (with the hydraulic lift cylinder) is attached to the front of the tractor (2 bolts and a pin), a driveshaft from the Mid PTO to the front of the tractor is snapped into place, then you drive forward into the arms of the snowblower, snap the latches into place, and connect the PTO shaft to the blower and 4 hydraulic hoses to the same ports as used by the loader. This takes 15 minutes at most. Very fast and easy with no manual lifting. I have a JD 955 but the same type of connections are used on the 4000 series tractors.
Thanks Jack. I guess the lack of responses from blue and orange indicates that the JD is the easiest.
Basically the same routine with a Kubota B7500HST - just a quick detach of the blower and hydraulic lines, roll away the blower, hook up the loader, and drive away.
If you are not absolutely set on a front mount blower, consider a 3ph blower and leave your loader on - it gives the tractor a lot more utility. You can pull snow away from doors/buildings that you can't get at with a blower - you can "blade" a light snow much more quickly - plus it's a whole lot cheaper......you can use the money saved to by a couple more 3ph implements!
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2012 CHEVROLET CAPRICE POLICE CAR (A66091)
2012 CHEVROLET...
John Deere R4030 (A64911)
John Deere R4030...
2007 Ford F-350 XL Lariat (A64911)
2007 Ford F-350 XL...
