Snowblower Changing from loader to front snowblower
/ Changing from loader to front snowblower #1
Anonymous Poster
Epic Contributor
I would like to hear from anyone who exchanges their loader for a front snowblower in winter. Which tractor in the 20-35 hp range is the easiest and quickest to make this exchange. I'm colorblind so I am interested in hearing from Deere, Kubota and Boomer owners. Thanks to all who respond.
/ Changing from loader to front snowblower #2
It is a very quick process to switch either way with John Deere compacts assuming the loader and snowblower are also JD. Loader installation/removal takes maybe 2-3 minutes. To install the snowblower, a small bracket (with the hydraulic lift cylinder) is attached to the front of the tractor (2 bolts and a pin), a driveshaft from the Mid PTO to the front of the tractor is snapped into place, then you drive forward into the arms of the snowblower, snap the latches into place, and connect the PTO shaft to the blower and 4 hydraulic hoses to the same ports as used by the loader. This takes 15 minutes at most. Very fast and easy with no manual lifting. I have a JD 955 but the same type of connections are used on the 4000 series tractors.
Thanks Jack. I guess the lack of responses from blue and orange indicates that the JD is the easiest.
Basically the same routine with a Kubota B7500HST - just a quick detach of the blower and hydraulic lines, roll away the blower, hook up the loader, and drive away.
If you are not absolutely set on a front mount blower, consider a 3ph blower and leave your loader on - it gives the tractor a lot more utility. You can pull snow away from doors/buildings that you can't get at with a blower - you can "blade" a light snow much more quickly - plus it's a whole lot cheaper......you can use the money saved to by a couple more 3ph implements!
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A61573)
2005 Anderson 24ft...
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
Caterpillar Vibratory Compactor Parts and Service Manuals (A63117)
Caterpillar...
2017 Case CX145D (A62177)
2017 Case CX145D...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
