Chainsaw recommendation
/ Chainsaw recommendation #21
Well I took the muffler off to take a peak inside, and everything looks pretty good! I went ahead and started to clean the saw up and took the sprocket off (took making a special tool) and I have decided to keep this saw for now and throw a bit of money and maintenance at it. I remember reading ages ago on the arborist site that some people were using a different sprocket to open up the chain options, since I have to replace the sprocket does anyone have any idea's.
BTW, I really appreciate all of the advice so far, I hope I have not offended anyone by asking for advise and now deciding to keep my current saw.
Thanks, Dave
There is no offense whatsoever. Just the opposite. At least you got back to all of us as every informed outcome helps someone else. It is way more offensive to have a list of postings to help someone out and that individual never gets back as to the outcome. That helps no one if the op just disappears.
I would not mess with what has worked well for you. Simply get a replacement sprocket that is part numbered for your saw as you have a saw that does not really lend itself to chain and sprocket deviations that a larger saw might take advantage of. The only thing I might change is getting a shorter bar if yours is not 16" already
Yeah I was thinking of getting some of the 16" bar/chain combo's from baileys.
Thanks again!
Dave
/ Chainsaw recommendation #23
If you are running 3/8LP Lo Pro chain. Try some Stihl 63PS3 3/8lp 050 full round chisel to wake your saw up in the cut.
hey xyz, if you do not mind? could you help me out with a link. When it comes to chains, if I deviate from what specifically is the style my saw came with it is all greek. BTW, are there any places that really describe all of these chain types? I understand the different chissel types, but all of the different numbers etc, are confusing. What exactly does 30lp mean?
Thanks, Dave
/ Chainsaw recommendation #25
My 2cents worth. I have a 025 whitch is the same as a MS 250 Sthil. Power to weight to cost ratio it can not be beat. It is a good rever. I have worked mine hard for ten years. Not everyday like a Logger mind you but at least two saturday's a month most of the year I am doing somthing. No it does not have Farm Boss power. But for me it is great. If I were to upgrade from this to a pro saw I would look at the MS260 PRO. This saw has about the same weight as mine but quite a bit more HP. It is about a $500 to $600 saw compared to the one I have at $300.00 The only time I could use more power is sawing up Logs over say 16 inch on a regular basis. My saw is a super fast at limbing and cutting up smaller logs without tiring me out. I had a 044 years ago and they are a beast in the big stuff. Just consider what all you are doing , How strong is your back, do you want a big saw all the time. You my need two saws. The Huskys are good too. but I don't know there sizes
/ Chainsaw recommendation #26
I've owned Poloun, Husqavarna, Stihl and Echo chain saws. I have two Stihl Chainsaws. they are nice saws. Much better then Poulan and Husky, which I consider low end saws. The Echo is much nicer then the Stihl, and while I'm curious about the Dolmer/Makita saws, I don't know of a local dealer. My Stihl dealer is also an Echo dealer. He pointed out to me all the advantages of Echo over Stihl, and now I'm sold.
Just like buying a tractor, only go where you can get suppport. Be sure that the dealer actualy supports it. When I took my Husqavarna in for work, I found out what a really crappy saw and company it was. Never again!!!!
Echo has a line that is sold at Home Depot that I don't know anything about.
What I have is sold at a dealer. It doesn't even look like the Home Depot saws, but I don't know if it's just the plastic, or if there are any other differences.
When reading recomendations, be sure to ask what other saws they have owned and used.
Eddie
/ Chainsaw recommendation #27
My dad owned an older 4400 Echo for years that was stolen...
It performed flawlessly for a long time...
Started easy and ran strong...
Anti-vibe system was very good...
Echo's are very well made and very dependable...
In my mind, they're quality is top notch...
I really like the air filtration system...
That automotive air filter set up is the cats meow...
You can pick those saws up very reasonable on E-bay...
I've heard that their power is lower than comparable Stihl's and Huskys in their pro series but I don't know that for sure...
IMHO, the Dolmar line in the 5105 and 6000/7000 series are the best saws in their class...
The biggest issue with them is spotty dealer support...
I have a very good dealer within 25 miles that has had them since they opened shop in 1981...
That would be my personal choice of saws...
/ Chainsaw recommendation #28
Thanks, Dave
I have already posted it before links below.
There is a thread on identifying stihl and oregon chain and Anatomy of chainsaw chain in the sticky threads and there is one on the new stihl chain 63PS3 http://chainsawrepair.createaforum.com/chain/
Very cool! XYZ there is a ton of information in that link! I love it, I am a bit of a information junky.
Thanks guys, Dave
/ Chainsaw recommendation #30
Did anybody get a copy of the "Carlton Chain Sharpening Complete Book" in PDF that they could share?
/ Chainsaw recommendation #31
Thanks, Dave
This will describe 30lp for you. It is woodsman pro 3/8lp chain semi chisel. Like stihl PM. Bailey's - WoodlandPro 30LP Chainsaw Chain
What chain do you have on saw now? Brand, numbers, and drive link count etc?
The PS stihl chain is round chisel not semi chisel like PM and PS cuts 15% to 20% faster in clean bucking cuts. You might want to stay with semi chisel. Just for the ease of finding the correct chains.
/ Chainsaw recommendation #32
Don't want a brand war, and I don't know anywhere near it all. I have had 2 poulans, 3 OLD homelite xl12s, 2 sthils-both of which were stolen within a week of purchase when I lived in the city. Since then, I have lived near a Husky dealer. Started out with a used131, and a new 345. Burned up the 131 in 2 years, but have had the 345 going on 4 years now with only plug changes and a carb rebuild. Bought a 359 last year, and it is great. Bought a well used 181 from the farmer up the road this summer. I do use them well, and have made over 15 full cord of wood this year alone, and need to clear out the 2 1/2 miles of tree line for the farmer, I get the wood for my heat, he gets an extra 5 feet width of field. I can't roof houses in winter, anyway.
Just a quick update, as I have become very busy the last few days, I got the parts on order to freshen my saw up, I got 2 new sprockets, some extra filters and ordered some new bar and chain combo's from baileys. xyz, I had the stock chain, or oregon direct replacement chain. It was the same style and size that the wild thing uses. I ordered this "This bar uses 56 drive links of .375 Low Profile pitch x .050 gauge chain (30LP-56)" or this Bailey's - Carlton 16" Hobby Champ Tiger Chainsaw Bar & Chain Combo. I am curious to see how it will work. I am excited about getting it running well again.
Thanks for all your help TBN!
Dave
Hey Gang just a quick update. I received the sprocket and bar and chain. Man this thing cuts great with this chain/bar combo. It really woke this little chainsaw up. This little saw should be good for me for quite a bit longer. I really appreciate all of the help!
Thanks, Dave
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
28" PIPE DRAG (A64276)
Coleman Powermate Generator (A62613)
Coleman Powermate...
