chainsaw quits running
/ chainsaw quits running #31
Well I tried all these things and it still cuts out and won't rev. Thinking it's fuel starvation. The carb was rebuilt once. Was thinking of buying a new carb on e-bay. It's an 025 Stihl that's about 20 years old. I just got a new Farm Boss but I like having a small light weight saw for limbing and medium logs.
The first chainsaw I bought was a used Stihl and it was acting just like yours. It turned out that the flywheel magnets were weak and would lose their magnetism when they got warm. Took the dealer a while to find that one!
/ chainsaw quits running #32
I'm debating if I should take it to the dealer, try a new carb or just write it off.
/ chainsaw quits running #33
I hear ya! Back then,(1973) you didn't have much choice vs the price of a new one. Now days you can get a saw off the shelf such as a Husky for $400 and if the dealer has a $60-80 labor rate, it won't take but several hours of labor and you might as well buy a new one. That applies to many things you buy now. Puts you in between a rock and a hard place.
/ chainsaw quits running #34
And since I have a Farm Boss 20" for the heavy duty work I could spend about $200 for a smaller saw. I'm just not a disposable kind of guy. I like to repair and keep using equipment.
/ chainsaw quits running #35
New carb for your 025 250 with H and L $21 at dealer and can do it yourself to install.
/ chainsaw quits running #36
H and L? That's why I was thinking of trying it. When I pulled the exhaust to make sure it wasn't plugged the piston looked ok. I see some carbs listed on Amazon but they aren't Walbro
/ chainsaw quits running #37
High and Low needles for full adjustments. Some just come with L
/ chainsaw quits running #38
I messed around with a saw all summer with similar problems. Started checking & replacing plug, fuel lines, filter, intake gasket, carb kits, then a $40 carb, Finally, I got it fixed when I spent another $120 getting the jug and piston replaced.
I should of spent $40 right off the bat on a compression tester that would of told me right away.
I wonder if my problems started with a bad carb pump or leak ( too lean), but during the time I was messing around with everything did I burn the piston up? Without the tester I'll never know where I was starting from. The Husky 55 is 19 years old so I don't feel too bad spending a little money.
/ chainsaw quits running #39
Right. The one I have now only has a low. It's a Walbro. Are the aftermarket carbs as good? Because they are cheap. I've seen them for $12-13 on Amazon and e-Bay. DO you have a preferred brand?
Thanks for the help.
/ chainsaw quits running #40
For $12 to $13 can you go wrong? The last carb I bought was off ebay for my 357xp. It wasn't the original brand but has worked just fine for years now. For the price I would just replace it vs rebuild it. Of course with ethanol being a way of life and it seams to find it's way into every gas tank I own carbs just don't last very long.
2019 VERMEER LP573 XDT VACUUM TRAILER (A59823)
2019 VERMEER LP573...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
Giyi 32" Excavator Bucket (A60463)
Giyi 32" Excavator...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
John Deere 4600 (A53317)
John Deere 4600...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
