Chains - Quick Question
/ Chains - Quick Question #51
I think it looks better and again, its gonna have more stability.
yeah. I need to look at the book (or draw/think it out). I may have gone from extreme inner to extreme outer positions.
It isn't getting changed for a few months (if at all), I'll tell you that much!
Man it was cold in the garage.
/ Chains - Quick Question #53
Hey, you don't know cold. LOL
I had to do some repairs the other day and it was -32 (your choice F or C).
Man I was glad when things got fixed!
At that temp my poor fingers can not tell the difference between a 1/2" bolt and a razor blade. Ouch!
/ Chains - Quick Question #54
Cold, I think I broke a nipple the other day.:eek::p
No, it wasn't a grease nipple.:confused2:
/ Chains - Quick Question #55
Whenever I'm contemplating some mechanics in the cold I place my hand tools indoors by a heat source (radiator) the night before. When you take them out the next day to use they retain some heat to the touch for an hour or two and make it all less painful. Of course you can't always predict when you might need them.
/ Chains - Quick Question #56
Those that have made a tire swap need to remember to check all the bolts for torque frequently for the next few times you use the tractor. The rim parts settle in during use and bolts get loose. By the third use and third check you shouldn't find anymore that have loosened up then you can go longer other then to visually check them while the tractor warms up.
/ Chains - Quick Question #57
tire rotation is important. They are built to go in one direction only. Hope yours are still ok. If you have to do a tire swap, then it could be the right time to have them filled. Filled tires makes a huge difference in traction and stability. Your chains are "light duty", go easy when spining, as they will disapear quick...:confused2:
My chains are light duty? Man, I'd hate to see heavy duty.
I don't spin....at all (now that I have the chains). So no problem there.
My tires are already filled with rim guard. They still point the right direction.
I do need to check the bolts. It was 6AM when I blew, so when I was done I had to get ready for work!
Oh, and -40 is where F and C are the same. Not -32. I know, fingers aren't that precise. It was probably 10 in my garage, and that was plenty cold. I have a circulation issue with pre-mature constriction of blood vessels in extremities, so feel it quicker than most.
/ Chains - Quick Question #59
This is what heavy duty looks like. :)
A mister heat. propane heater in the garage can take the chill off in a big way. Just give it clear space in front of the burner and crack a window for ventilation.
https://images.search.yahoo.com/ima...=yhs-mozilla-001&hspart=mozilla&hsimp=yhs-001
I had one of these heaters going, but still......
http://www.masterheaters.com/Desa_images/blp50v.jpg
Then all my tools get a layer of frost, due to the moisture from burning the propane.
I just need to get insulation in the attic and hook up the radiant floor. Then haul a BUNCH of extra firewood.
All on my todo list........
2019 International DuraStar 4300 24ft. Box Truck (A59230)
2019 International...
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
CH and E 2909T 6in Towable Trash Pump (A59228)
CH and E 2909T 6in...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2018 Ford F-150 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
