Chains for Lifting Objests With FEL
   / Chains for Lifting Objests With FEL #31
Oh, now I see; you guys with the pretty blue tractors are picking on me. /forums/images/graemlins/laugh.gif If I can't get my orange pumpkin fixed right and buy blue again next time, can I be in the club? /forums/images/graemlins/grin.gif
Just joking, obviously. Well, maybe... Anyway, it's nice to be able to debate without tempers flaring etc. Right now my temper is flaring against a company that makes orange tractors. So, since blue is my favorite color, you'd better agree with me or I might just come borrow your pretty blue tractor in the middle of the night! /forums/images/graemlins/wink.gif
   / Chains for Lifting Objests With FEL #32
Dargo that's one of the main reasons that I really like TBN.
We all have our own likes and dislikes, we share ideas and information.
And we are all free to use those ideas or dispose of them as we see fit.
And we can agree to disagree on threads and still be friends.
I do value your input. /forums/images/graemlins/grin.gif
   / Chains for Lifting Objests With FEL #33
OK, I have a question for all. I have not bought my chains yet, been a TSC convert for a year or so now on bolts and just about anything that I can get elsewhere, but always give them a shot.
Should I buy my chains there, dont need something to pull down a barn, but something to move my mower around, strap something in the bucket, stuff like that. I figure 5/16 hardened, with appropriate hooks will do, 15' or so.
   / Chains for Lifting Objests With FEL #34
Danny,
That's where I just bought mine and yes I can tell you they said made in China.
I bought 5/16 so for my BX1800 that should be plenty enough.
   / Chains for Lifting Objests With FEL #35
Well here's my two cents...
I haven't kept track of names here but I'm going to respond to a couple comments and then tell two stories of what happened to me.
First, someone said Harbor Freight buys the cheapest products available. I disagree, apparently the person saying this has never shopped at a Homier show. Their Chinese products make Harbor Freight products look like they're made by John Deere or New Holland. /forums/images/graemlins/laugh.gif
Someone commented that they would never buy a jack or any product from Harbor Freight which would be unsafe if it failed. At one time, I didn't agree with this but, I was a fool. Now I strongly agree!
About four months ago, I bought a "Farm Jack" from Harbor Freight. It was rated at 600lbs. Since I never intended to lift anything near that heavy with it, I thought it would be ok. Wrong!
I needed to tip my front end loader forward. I could almost do it myself. I could lift the one of the arms off the ground slightly but needed another strong person to lift the other one a the same time. I thought ok, I'll use the HF farm jack. So I started jacking it up and it lifted it effortlessly. As I started to jack it down, it hung up. It wouldn't jack down correctly. Suddenly, the jack just let go and the FEL tipped backwards towards me and crashed to the ground. It missed my foot by inches. Had that steel FEL arm dropped three feet and landed on my foot it would have crushed it.
Here's what I found. In the HF Jack, there are two pins. One of the light weight none hardened pins bent and allowed the jack to fall. I took the jack back to the Harbor Freight store and explained that I believed the jack had improperly heat treated components. The store clerk clearly didn't have a clue what I was talking about but refunded my money.
Two lessons learned.
1) Don't trust your life and health to Chinese quality control.
2) Buy a good pair of steel toed shoes when working with your tractor.
Also, when lifting anything using the FEL. Be careful. I recently attempted to lift a crate with a nylon strap. I had the strap attached to both sides of the FEL (mistake #1). One end of the strap was a little tighter than the other, I though the strap would slip and equalize the lifting force (mistake #2).
As I lifted, the 7000lb tractor suddenly (in half a second) flipped up onto two wheels and nearly flipped over. I was sitting still at the time without the seatbelt fastened. I could have easily been pitched out of the drivers seat and under the ROPS had it gone all the way over.
I learned that when the FEL is lifted, the center of gravity of the tractor is much higher than you would think, any side load can flip the tractor VERY EASILY.
Good Luck,
I enjoyed this thread a lot.
Jerry /forums/images/graemlins/cool.gif
   / Chains for Lifting Objests With FEL #36
Good story. Buyer beware!
A I said, you must watch HF. I personally inspect and evaluate everything I buy there, and take personal responsibility for being a cheap skate. You can get away with it if you play it smart. I have been very lucky so far. All my purchases have been very good save for a .99 special or 2.
I restrict my HF purchases mostly to tools that don't do any lifting or holding. Their chains are DOT graded and approved, and 4x more than I can break, so I trust them. (besides, I took a good look at them before buying). Their $10 disk grinders and $24 1/2" 110v hand drills are SUPER values and decent quality. Their 1 HP 16" drill press is too. None of these will fall on you! I have never bought a jack, lift, wench, or anything hydraulic from them. Those items are too hard to examine unless I borrow a friends and thoroughly check it out first. I am acutely aware of proper heat treating. In another life, I was in charge of 2 matallurgy labs among other things, and I know that metal isn't metal.
   / Chains for Lifting Objests With FEL #37
After snapping in half a brand new 3/8" Grade 43 chain, which has a working load limit (WLL) of 5400 lbs, with the FEL on our L39 while loading a tree stump, I am using only AMERICAN made Grade 80 1/2" chains with a WLL of 12,000 pounds from now on. But I have to admit, the 200 foot drum of this great chain is very heavy!
http://www.1st-chainsupply.com/chain/gr80_spec.htm
   / Chains for Lifting Objests With FEL #38
</font><font color="blue" class="small">( None of these will fall on you! I have never bought a jack, lift, wench, or anything hydraulic from them. )</font>
Okay, I'm the guilty party of bashing HF because of my bad experiences with exactly what you mentioned you haven't bought there. /forums/images/graemlins/blush.gif I'm sorry, but I about fell out of my chair laughing when I read your "none of these will fall on you". I'm still giggling like a kid as I type this. /forums/images/graemlins/tongue.gif I could just picture you like my father telling me "you dummy, use some sense about what you buy there!" /forums/images/graemlins/crazy.gif
You are right, there are some bargains to be had there. You just need to be smart enough to judge what is a bargain and what will potentially kill you. I'd been guilty of not knowing that in the past; that is why I'm the HF ****. /forums/images/graemlins/blush.gif Yes, you'll still find me lurking in the isles there (in disguise) but I won't buy anything there that will injure me or damage my other equipment if it fails.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1608 (A57192)
1608 (A57192)
