Loader slowly lowers itself when under a load.
   / Loader slowly lowers itself when under a load.
All hydraulic implements will settle over time. Even if the cylinder piston seals and control valve are good, a small amount of oil will seep through somewhere. If it goes down fast enough that you can actually see it move while watching it, then that's too fast. Large farm tractors and some industrial equipment have load check valves in the loader control valve to prevent the implement from lowering unless the lever is moved to the lowering position with the engine running. Small tractors do not have load check valves in the loader control valve, so some oil is going to go between the spools and the bores in the valve. LS had some trouble with certain cylinders on some models. LS does not make these cylinders or loaders. They are made by Taesung or Ansung, depending on the model. Early LL1101 loaders on MT1 tractors had defective bucket cylinders that would leak down rapidly. The cylinder tubes were rusty inside from the manufacturing process. The cylinders are washed before being painted and wash water leaked inside causing rust. They now improved the plugs in the cylinder ports so water can't leak in during the wash process. Recently, some new model snowblower subframes (not for 225S) are having issues with lift cylinders leaking down rapidly.
Thanks for the response. I will keep an eye on the settling speed to see if it increases. Nice to know the back story on some of the components too.
   / Loader slowly lowers itself when under a load. #12
I don't understand how leaky piston seals can cause the cylinder to to leak down. If we take it to the extreme just imagine a cylinder without a piston. Pushing on the rod will try to compress the oil and since the oil is almost incompressible the rod won't move. And pulling on the rod will cause a suction and the only way the rod can move is if the oil starts to vaporize. What am I missing?
Eric
If you have a specific volume of oil on the pressure side of the piston, it will hold the load in place. If the oil bypasses from the pressure side of the piston to the other side, you lose some volume of oil and the piston will move. Changing the volume of oil on either side of the piston is the only way to make a 2 way cylinder move. If there was no piston, it wouldn't move when we fill opposite ends with oil.
   / Loader slowly lowers itself when under a load. #13
@farmiguy - you might ask your dealer about cylinder recall. Our LS had a droopy bucket... It was brand new, less than 50 hours on the clock. bucket should not droop like it was.
Dealer said to check for leaks.. we did. There were none.
I checked here on the forum. Some wise member said there was a recall on loader cylinders.
Told our dealer.. Yep... our tractor was part of the recall. LS will not notify you. You must ask about it. I suggest you ask.
Thanks for the recall info. I will check with my dealer to see if it would apply to my issue.
   / Loader slowly lowers itself when under a load. #15
There wasn't really any recalls on cylinders, it was fix as fail only. There were some service bulletins and tech bulletins sent to the dealers informing them of changes made in the cylinder manufacturing process because of high failure rates on certain cylinders. Customers are only notified if there is a campaign or PIP (product improvement program), which are terms they use instead of recall. Checking the bulletins is the only way for the dealers to see if they pertain to your problem. They should be checking them often to stay informed. Some bucket cylinders on early LL1101 loaders had oil bypassing the piston internally, and boom cylinders on some other model loaders had poor welding which caused oil to leak externally through the welds. According to my dealer, there aren't any bulletins regarding cylinders on loaders for a MT225S, but there is a bulletin for the loader valves leaking on this model because of o-rings blowing out around the valve spools. Don't worry, the bulletin explained how this has been fixed. This was discussed in another thread back in October 2024.
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
2020 Chevy Silverado (A56438)
2020 Chevy...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
