Chain Storage
/ Chain Storage #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
I have a 4320 and was wondering if anyone had a good idea where to store tow chain on the tractor. I know that JD has a tool box that attaches to the front of the tractor, but I really don't like that option.
The dealer said not to weld on the tractor cause it would void the warranty do to all of the electronics. This really limits my ideas. I have seen what others have done on different tractors but would like to see what could be done on a 4020 series..
Thanks
Dave
/ Chain Storage #2
Thanks
Dave
My tractor has the battery box and weight bracket bolted to the front of the frame below the radiator. I find that the hooks on the chain slip over the top of the steel that the bracket is made out of. I just wrap the chain around the weight bracket just behind the weights, in front of the battery box no box required.
This photo shows the bracket. It makes the chain very easy access. I use it a lot.
/ Chain Storage #3
Someone described putting chain in the cross-tube open part of the FEL - making some sort of cap to hold it I presume. Don't know if it would work.
/ Chain Storage #4
I recommend a piece of PVC pipe attached to the loader vertical frame. Use a cap on the bottom with some drain holes drilled in it, or cut some thick plywood to cap it.
The chain(s) fall right inside and the hooks hook on the top lip.Even takes paint.Maybe like mine there are some avail holes predrilled to bolt it on with
/ Chain Storage #5
Running a quick-hitch/I-match style? If so its a good place to add up to 4 boxes---see pic. Good luck.
/ Chain Storage
Now thats a good idea. I had a quick hitch but sold it with my other tractor. I now have the expandable lower links which I think work much better. They seem to be less effort to connect to my implements. I guess I could but a chain box on all of them.
/ Chain Storage #7
Built one today! Works great! Thanks for the idea.
Jim
/ Chain Storage #8
dj1701,If you could do a picture I would appreciate it ,I have been trying to find where you set your pipe and what diamater/ length.What a great Idea
/ Chain Storage #12
Here is another variation similar to Pipestone's.
4" pc of PVC cut in half, hose clamped to the loader uprights. My chain bucket wasn't big enuff to hold both chains so I made this setup. The hooks hang on a pc of 2x3" sq tube that is bolted to the upright (and yes the holes were already there). The smaller pc of pvc holds pry bars, long handled monkey wrench, and whatever else won't fit in my toolbox.
/ Chain Storage #15
Here you go. Excuse the quickie paint job!
Your chain "bucket" is very similar to mine. My design is "pinned" in so I can pull out a pin and pull the entire chain bucket out.
/ Chain Storage #17
I couldn't get along without my iMatch... with the hyd. top arm. Regularly change off with rotary mower, forks, turbosaw, chipper, ballast box, rear blade, and carry-all. Haven't fitted the rototiller for the iMatch yet, as only mount it one or maybe twice a year.
Now store/carry my chains in the ballast box, but eyeing the other ideas mentioned in this thread. There are some good ones.
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
