Loader Chain Grab Hooks
   / Chain Grab Hooks #2
Bolt on hooks are fine.............
   / Chain Grab Hooks #5
Ken's bolt on hooks are fine. I have them on my Quickie FEL on my 3930. The 1/2" diameter grade 8 bolts are a whole lot stronger the the 3/8" chain. The mounting and brackets are well made and tough.
   / Chain Grab Hooks #6
Agree with those above ^^^^^
I like and kind of prefer the weld on idea. BUT if they are welded wrong and / or onto the wrong type or thickness of material or the wrong angle they are a lot weaker than the bolt on idea.
   / Chain Grab Hooks #7
If the material is thin a backing plate should be used in either application.
   / Chain Grab Hooks #8
This is what I did, fabed up from 2x2x1/4 inch angle iron and slots cut for 1/4 or 5/16 chain.... Grade 8 bolts....
Yes a tad bit of welding on one below...
Dale
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2019 Kubota SVL95-2 (A53317)
2019 Kubota...
2003 International 4300 S/A Day Cab Truck Tractor (A55852)
2003 International...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Mini Margaritaville Truck (A55853)
Mini...
