Chain Binders
/ Chain Binders #11
Might be a silly question, but after much searching I'm not really finding it. What weight capacity do I need for a ratchet binder?
I'm towing a Kubota BX23, around 2700#. I picked up some 5/16"-3/8" binders and some 5/16" chain. It all works great, but I was thinking those smaller sized binders out there might be more convenient. The binders I have currently have a WLL of 5400#. The smaller 1/4"-5/16" binders I see out there have a WLL of 2600#. Obviously the WLL doesn't need to match the weight of the load, so what's the rule of thumb for figuring what WLL I should have for the load I'm carrying?
My advice would be worth just what you pay for it so, instead, I'll tell you what I would do.
Keep the heavier binders. You never know when you might want to transport something bigger.
Buying an extra set of smaller ones is good too.
/ Chain Binders #12
Your 5/16" chain of grade 70 has a WLL of 4,700 lb. I would use binders with at least a WLL of that. No sense in making your binders the weak link even if the chain is overkill. I have some 1/4" chain and binders we use on UTVs and I have 1/2" chain and binders we use on heavy equipment. The chain gets darn heavy and cumbersome but the varying binder sizes never bothered me. A 5/16"-3/8" binder is not hard to work with at all I actually prefer messing with them than the tiny 1/4" ones.
/ Chain Binders
I'll definitely be keeping the ones I have. I was just considering getting the smaller ones for ease of handling when working with a lighter load.
/ Chain Binders #15
I have the folding handle type also, worth the money and honestly not that much more then a decent non folding handle type.
I have some of the cheap ratcheting ones & recently picked up some yellow folding ones as pictured. I have lost track of where the cheap ones are hiding & don't care. Only using the nicer folding ones now.
Personally I chain the front bumper to some D-rings up front. Put the tractor into 4wd& low range. Backup until the tires spin then jam on the pinned parking brakes. Chain the back of the tractor to 2 more D-rings & then use the chain binders on the rear 2 chains. No binders on front, but everything is TIGHT.
I do slack a bit chaining or strapping the loader & attached impliments. I rarely tow more than 15-20 minutes though. If it's any kind of distance I chain or toss a strap over.
I recently chopped some of my 20' chain in half. Makes it so much nicer having things about the right length. Slip hooks on one end to attach to clevises is better than chain hooks. I'm also a recent convert to the twist lock chain & slip hooks from Ken's Bolt on Grab Hooks <<Home>>. really nice to have a beefy metal tab keeping the hooks from dropping loose as opposed to that tinfoil clip on most slip hooks or nothing on chain hooks.
Having enough of the right length chain with good hooks & binders makes an annoying job a lot easier.
/ Chain Binders #16
For a lightweight BX, if I had a place to attach a strap without cutting, I would use heavy duty straps to tie it down. It doesn't make any difference what you use as long as the WLL is sufficient. Ratchet straps are much easier to work with than chain and binders.
/ Chain Binders #17
I run a 5/16 grade 70 chain through behind the brush guard in the front, then a 3/8 grade 70 chain through a clevis on the drawbar. Tighten down with ratchet binders and use HD ratchet straps for the bucket and an implement if attached
/ Chain Binders #18
Not for me. I have 4 short chains and 4 ratchet binders.
/ Chain Binders #19
I agree. If you cut chains to the right length they are easy to use. Easier than straps I think and they sure last a lot longer. Straps fray, wear, and break. I recently had a good quality name brand strap break at the sticking with no obvious signs of wear. I carry straps in the truck for light weight things but use chains on anything bigger. I will agree throwing around a 20' chain when you only need 3' of it is no fun but sized properly they are great. I even have some things set up where I don't even need a chain and just use a ratchet binder.
/ Chain Binders
I used to always think I would prefer straps. I have and still use them for quads, things like that. But I must say after having used the chains on the BX this past weekend, I think for tractors of the BX size and up, I really like the chains. I actually found them less of a hassle to use than straps.
2020 DRAGON 150BBL ALUMINUM (A60736)
2020 DRAGON 150BBL...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
