chain and strap storage?
/ chain and strap storage? #11
i like plastic 5g buckets with lids ( or plastic cat litter boxes with tops ) for chains... straps probably be ok to but don't fit as well..
soundguy
/ chain and strap storage? #12
If you have the loader for your L3400, you can use the loader cross tube to store a chain in, there's a pic here somewhere of one with plastic plumbing expansion plugs in both ends to keep the chain in.
Sean
/ chain and strap storage? #13
I know you wanted a metal box but I use a piece of 4" ABS pipe bolted to the loader upright to store chains and straps -- the bottom is a cap with a couple of drainage holes drilled in it.
Any pics ?
I would like to see how you have done the 4 PVC Setup.
thks/ltr
/ chain and strap storage? #15
/ chain and strap storage? #16
I made this for my JD 790, fits in the factory grille guard, behind my homemade grille screen.
Screen hooks over top of chin box with a long pin through the top pipe of the factory guard. ~~ grnspot
/ chain and strap storage? #17
for me, i have found out hard way. that little metal tool boxes ya pick up like at sears, or a fishing lure box. are not so great. to a point the locks and hinges will bust rather quick or come open on there own.
5 gallon buckets is what i use. when i have the draw bar on the allis chalmers CA. i had some scarp metal laying around. and built a little C shape like support off the rear. then use a couple large bolts like hooks for the handles on the 5 gallon buckets. they work well for when i have the 100 foot cable i use for pulling some smaller size trees out of the woods.
if you have room between front and rear tires and high enough off the ground. drill some holes put a bolt through the frame. and get a large S hook that you can Squeeze one side down and around the bolt. to hang 5 gallon buckets off of.
there be another post in last couple days, of folks using 5 gallon buckets like soundguy and myself to load tools up into in the shop. then carry the 5 gallon buckets around to different projects.
for me it generally requires 2 to 3 buckets for a given project. one for tools, and other 2 for given materials or extra tools.
for chains, 5 gallon buckets tend to be easier. due to you have a lip you can hook end of chain to. and let the rest of the chain get mixed up in the bottom of the bucket without getting into to much of a mess.
if you have a ROPS or FOPS on your tractor. they make good mounting spots for 5 gallon buckets.
word of warning though. tractors love to bounce. and anything in a 5 gallon bucket, or tool box is likely to bounce out when you least expect it to.
/ chain and strap storage? #19
hey now.. I like that idea! I may have to add a chain box to my 4600's bumper!
soundguy
/ chain and strap storage? #20
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2006 INTERNATIONAL L9227(INOPERABLE) (A60736)
2006 INTERNATIONAL...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A60352)
2022...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
