chain and strap storage?
/ chain and strap storage? #11
i like plastic 5g buckets with lids ( or plastic cat litter boxes with tops ) for chains... straps probably be ok to but don't fit as well..
soundguy
/ chain and strap storage? #12
If you have the loader for your L3400, you can use the loader cross tube to store a chain in, there's a pic here somewhere of one with plastic plumbing expansion plugs in both ends to keep the chain in.
Sean
/ chain and strap storage? #13
I know you wanted a metal box but I use a piece of 4" ABS pipe bolted to the loader upright to store chains and straps -- the bottom is a cap with a couple of drainage holes drilled in it.
Any pics ?
I would like to see how you have done the 4 PVC Setup.
thks/ltr
/ chain and strap storage? #15
/ chain and strap storage? #16
I made this for my JD 790, fits in the factory grille guard, behind my homemade grille screen.
Screen hooks over top of chin box with a long pin through the top pipe of the factory guard. ~~ grnspot
/ chain and strap storage? #17
for me, i have found out hard way. that little metal tool boxes ya pick up like at sears, or a fishing lure box. are not so great. to a point the locks and hinges will bust rather quick or come open on there own.
5 gallon buckets is what i use. when i have the draw bar on the allis chalmers CA. i had some scarp metal laying around. and built a little C shape like support off the rear. then use a couple large bolts like hooks for the handles on the 5 gallon buckets. they work well for when i have the 100 foot cable i use for pulling some smaller size trees out of the woods.
if you have room between front and rear tires and high enough off the ground. drill some holes put a bolt through the frame. and get a large S hook that you can Squeeze one side down and around the bolt. to hang 5 gallon buckets off of.
there be another post in last couple days, of folks using 5 gallon buckets like soundguy and myself to load tools up into in the shop. then carry the 5 gallon buckets around to different projects.
for me it generally requires 2 to 3 buckets for a given project. one for tools, and other 2 for given materials or extra tools.
for chains, 5 gallon buckets tend to be easier. due to you have a lip you can hook end of chain to. and let the rest of the chain get mixed up in the bottom of the bucket without getting into to much of a mess.
if you have a ROPS or FOPS on your tractor. they make good mounting spots for 5 gallon buckets.
word of warning though. tractors love to bounce. and anything in a 5 gallon bucket, or tool box is likely to bounce out when you least expect it to.
/ chain and strap storage? #19
hey now.. I like that idea! I may have to add a chain box to my 4600's bumper!
soundguy
/ chain and strap storage? #20
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2001 John Deere 6210 (A60462)
2001 John Deere...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60352)
2014 Chevrolet...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
