chain and strap storage?
/ chain and strap storage? #1
HiTechTed
Gold Member
Indiana
Kubota L3400
I want to build myself a metal box to put up front (maybe down at the bottom of the brush guard) to store chains and tow straps in. I've seen one example on here that somebody made with a cnc plasma cutter but I'd like to see some other examples if you guys have made something for this purpose. It shouldn't be a difficult project (even I can make a box with a lid) but I'd like to see some other examples. The more the merrier!
/ chain and strap storage? #2
If you get much rain or moisture maybe have some drainage hole in the bottom so straps and chains don't get moldy or rusty. A plastic milk crate works for me on the fender.
The drainage holes are a good idea. And while I'm at it, could you guys point me to some good quality tow straps? The ones I got at a local farm supply have ripped on me and I bent one of the hooks. It's probably my fault, I use them to drag trees and things around with because they are easier to handle than chains IMO....+
/ chain and strap storage? #4
Check out the box 4shorts made for the front of his Kubota.
/ chain and strap storage? #5
I am acutally in the process of adding a chian storeage box to my grill guard for the front of my Kubota M9540. I plan to cut a couple of holes in the bottom for drainage and a 2" receiver because they always come in handy. I hope to be done this weekend or early next week. Will post pics then.
/ chain and strap storage? #6
Those chains and strap brackets are rust magnets. I would suggest using a grate or expanded metal for the bottom. That would also drain better if the stuff is used in the mud.
An even better idea! Plus I already have some expanded metal I can use. I think I've seen the one 4shorts made.
Great, pics are always good!
/ chain and strap storage? #9
I just used a cat litter box that has a snap on lid. It is about 14 inches tall and 10 inches square. I keep tow straps, lifting straps, a couple of ratchet straps in it usually.
Last summer I added in some paper towels, torpedo level and line marking paint. I use the line marking paint to mark the rocks I find while mowing the field....
I've looked at several options for metal boxes and such and haven't found anything that suits me. Unfortunately, most of the plastic one's out there aren't very sturdy or suited for the cold we get up here.
regardless, a drain hole is important. Even a "damp" strap will cause condensation to build up over time.
/ chain and strap storage? #10
I know you wanted a metal box but I use a piece of 4" ABS pipe bolted to the loader upright to store chains and straps -- the bottom is a cap with a couple of drainage holes drilled in it.
/ chain and strap storage? #11
i like plastic 5g buckets with lids ( or plastic cat litter boxes with tops ) for chains... straps probably be ok to but don't fit as well..
soundguy
/ chain and strap storage? #12
If you have the loader for your L3400, you can use the loader cross tube to store a chain in, there's a pic here somewhere of one with plastic plumbing expansion plugs in both ends to keep the chain in.
Sean
/ chain and strap storage? #13
Any pics ?
I would like to see how you have done the 4 PVC Setup.
thks/ltr
/ chain and strap storage? #15
/ chain and strap storage? #16
I made this for my JD 790, fits in the factory grille guard, behind my homemade grille screen.
Screen hooks over top of chin box with a long pin through the top pipe of the factory guard. ~~ grnspot
/ chain and strap storage? #17
for me, i have found out hard way. that little metal tool boxes ya pick up like at sears, or a fishing lure box. are not so great. to a point the locks and hinges will bust rather quick or come open on there own.
5 gallon buckets is what i use. when i have the draw bar on the allis chalmers CA. i had some scarp metal laying around. and built a little C shape like support off the rear. then use a couple large bolts like hooks for the handles on the 5 gallon buckets. they work well for when i have the 100 foot cable i use for pulling some smaller size trees out of the woods.
if you have room between front and rear tires and high enough off the ground. drill some holes put a bolt through the frame. and get a large S hook that you can Squeeze one side down and around the bolt. to hang 5 gallon buckets off of.
there be another post in last couple days, of folks using 5 gallon buckets like soundguy and myself to load tools up into in the shop. then carry the 5 gallon buckets around to different projects.
for me it generally requires 2 to 3 buckets for a given project. one for tools, and other 2 for given materials or extra tools.
for chains, 5 gallon buckets tend to be easier. due to you have a lip you can hook end of chain to. and let the rest of the chain get mixed up in the bottom of the bucket without getting into to much of a mess.
if you have a ROPS or FOPS on your tractor. they make good mounting spots for 5 gallon buckets.
word of warning though. tractors love to bounce. and anything in a 5 gallon bucket, or tool box is likely to bounce out when you least expect it to.
/ chain and strap storage? #19
hey now.. I like that idea! I may have to add a chain box to my 4600's bumper!
soundguy
/ chain and strap storage? #20
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
Toro (A56857)
Toro (A56857)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
