Quick Hitches Cat I Quick Hitch
/ Cat I Quick Hitch #1
Frosty
SW Idaho
Kioti CK35 HST; Kubota KX040
Does anyone know of a 3 pt quick attach hitch for a Cat 1 tractor (i.e. CK35) that will fit Cat 1 implements 7/8" pins? Everything I find for Cat 1 quick attach hitches require bushings for a Cat 1 implement to fit it. Somebody must make a Cat 1 for Cat 1 implements.
/ Cat I Quick Hitch #2
Never saw one. Specs call for Cat 3 hook size for a Cat 1 hitch.
It may be possible to find an old, off-spec one that has some smaller hooks. One of mine has Cat 2 lower hooks.
Or you could weld in a liner in the hook to fill some of the space.
Bruce
/ Cat I Quick Hitch #5
Cat 1 QHs all have the large hook openings; reason is probably to provide more bearing surface to reduce wear on the 7/8" and 3/4" pins. Have your dealer look up the Land Pride parts for their QH and QH implements. They have the bushings to increase the Cat I pins to the QH hook sizes, plus the flex straps for those implements such as brush hogs that need to ride up over humps.
Ron
/ Cat I Quick Hitch #6
Cat 1 QHs all have the large hook openings; reason is probably to provide more bearing surface to reduce wear on the 7/8" and 3/4" pins. Have your dealer look up the Land Pride parts for their QH and QH implements. They have the bushings to increase the Cat I pins to the QH hook sizes, plus the flex straps for those implements such as brush hogs that need to ride up over humps. Ron
Guess you didn't look at the one i posted above then.
/ Cat I Quick Hitch #7
Bushings are a 'way of life' when using any 3ptQH. You may get away with one or two implements, if you're lucky, but the ease of picking up multiple implements from several different manufacturers, even with an agreed on 'standard configuration', are pretty much gone without them.
I've had to employ an extender to the top link on at least two of my Cat 1 implements.
In a perfect world... every implement would fit. That aint goin' ta happen.
/ Cat I Quick Hitch #8
Yes, SpeeCo makes one, it's call a Cat 1 E-hitch.
SpeeCo Products
That's a real descriptive website (*intense sarcasm*). Although the important fact that it's available in black is listed. If I ever get into selling a product(s) on-line I'm going to really go into detail to describe it for the potential customer.
/ Cat I Quick Hitch
Ignoring the sarcasm; I could never figure out the stepped bushings like SPEECO. The LP ones are the same OD for the entire length. I bought several of their longest ones then cut to fit the oddballs on spacing.
Ron
Thanks everyone for your input & explanations. I figured this has been beat to death but I couldn't really find an answer until after I posted, and I looked and read for a couple hours. I am going to get a hyd. top & lift cylinders. I read one post that a fella tried several quick hitches and settled on Pat's hitch. I am thinking that might be the best answer. Otherwise sounds like a lot of modifications, with my luck, to just about everything. Still need to attach PTO anyhow for tiller, phd and possible additional implements. I had a Harbor Freight quick attach couple yrs ago and took it back because the Top hook was to low and had no adjustment. Boy O' Boy - to fish or cut bait? Frosty
/ Cat I Quick Hitch #11
I've had both, QH and Pat's. Which is best totally depends on how often you hitch/unhitch your equipment.
With a QH and TnT it's extremely easy to hookup. Don't even have to worry about dropping on level ground. If not using a PTO attachment it can be done without leaving the seat.
With Pat's you will be required to get off the tractor EVERY time you hookup.
All that said, if you don't have the capability to modify your implements you probably should get Pat's. If that's the route you take, and you never use a QH, you'll be a satisfied customer!!! :)
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
