Case IH 885 Front Wheel Problems
/ Case IH 885 Front Wheel Problems #11
I got hub off. Worst case scenerio..... everything from u-joint to ring gear will need replaced except housings. One sun gear bearing seemed tight, maybe that started the destruction. I'm guessing 1500 in parts, any thoughts.
I'm thinking you'll be lucky to fix it for that $1500.
What do you guys think about used parts ? I did some checking and new would be around $3000 , whereas used would be around $1500 ?
I got new parts coming. I'm still not sure what caused this failure. Do you guys think I should tear the other side apart to check it ?
Thanks, I'll let you guys know when my parts get here.
/ Case IH 885 Front Wheel Problems #16
As RickB suggests at least drain the oil and see what comes out
Do you need the service manual section ?? i can do at reduced cost, drop me a PM ??
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2014 Freightliner Derrick Digger (A60352)
2014 Freightliner...
New Holland 3930 (A60462)
New Holland 3930...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
