Case DH4B Trencher/Backhoe Won't Spin Trenching Chain
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain
Would you mind double checking based on this diagram?
If it is on the charge pump inlet, I can’t think of any reason why it would be there. It would only lead to more pressure drop that makes it more difficult to get oil into the inlet of the charge pump.
The only place that a check valve would make sense is on the case drain. If it is on the case drain port then it wouldn't let oil flow from the tank to the pump case. I have seen that if there are case pressure spikes from another component and they are trying to isolate the pump case from those events.
If it is on the charge pump inlet line, I would remove it. If it is on the case drain line, I would make sure it is working properly and the oil can flow from the pump to the tank. It should not take much force to open it. If it does, I would be concerned about it causing high case pressure in the pump.
Here is a photo of the 1/8 gauge port that I put an elbow in to get a gauge on it.
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #42
Thanks for the pictures, that helps tremendously!
I have looked at your pictures and have marked up the picture to show the case drain versus the charge pump inlet. The check valve that you showed is on the case drain, which makes more sense.
In the picture you show a gauge port. Where the threads 1/8" pipe? If so, that is a system gauge port. You can measure charge pressure there but only in neutral. In one direction that will become system pressure, in the other direction that will be slightly lower than charge pressure.
R8,
attached is parts break down on a Sauer Sunstrand (now Danfoss) series 40 pump. This will hopefully provide a visual aide in how these model pump is assembled. Other brands would probably be similar but none of the rotating group would interchange.
Hope this helps Vs hinders
I see you are in Northern Illinois, I am in Lake County, do you work on pumps?
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #44
R8
I used to work for a company that rebuilt hydraulic components but not anymore. Not even sure what repair houses are open anymore in Chicago land area. Used to be a good outfit in Elk Grove but don’t recall the name anymore.
If I have continued issues with this pump, can you recommend a repair kit? I would give it a try in rebuilding it myself.
So what you have on that machine is an old Sauer-Sundstrand 18 Series pump. The model number is 18-2081. For Sundstrand/Danfoss, anytime you see a "R" at the end of a model number, it indicates that it has been remanufactured.
The "LH" indicates that it is a Left Hand rotation pump (counter-clockwise). If the pump was sitting in front of you with its input shaft facing you, the shaft would need to rotate to the left, or counterclockwise.
Since we know that it is an 18 Series pump, we also now know that it is a closed circuit system. Oldnslo had already mentioned that based on the exploded view diagram.
Based on what you have described so far, my first thought would be to check for charge pressure. I believe oldnslo has also mentioned that in one of his posts. The problem with a direct displacement pump, is that you can force it into stroke without charge pressure. Without any charge flow, there is no oil in the circuit to send from the pump's rotating kit to the motor and thus no trencher chain movement.
The noise that you are hearing from the pump could be the charge pump running without any oil. If that has been going on for a while, then you may have an issue because those parts rely on an oil film to keep them from damage.
I would first start by making sure you have oil getting to the inlet of that pump. The inlet of that pump can be found on the diagram that is attached.
I would crack that hose fitting at the pump and see if oil is reaching the pump. If not, you will need to backtrack it to figure out where the obstruction lies. There may be a suction filter or screen that is plugged.
If you have oil at the inlet, then get a 500psi gauge and plumb it into the charge pressure gauge port and see what pressure, if any, the pump has when the engine is running. It should be at least ~100 psi. Some of the 18 series pumps ran fairly low relief settings so don't be surprised if it is at that level. It may be higher, but it shouldn't be lower than that.
In case you are not familiar with a closed circuit system, here is a system that should be similar to the one that is on your trencher.
Keep us posted on how your investigation goes. We can help direct you based on your findings.
Ok, I have oil at the pump via the inlet port, cracked the line and I have 100% flow. I connected a hydraulic pressure gauge into the 1/8 pipe gauge port and the gauge reads between 80-100psi. It bounces between the two numbers. Now I really can't run it through the paces since it its low on hydraulic fluid (still need to get more) and I am still making more replacement hoses for other accessories and I am waiting on a hydraulic cylinder to come back from the rebuilder. Is the 80-100psi good? What's next?
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #47
R8
Since there is charge pressure with no movement command next step would be seeing what happens to charge pressure when you attempt to turn the chain. Remember where you have the gauge will be high pressure in one direction.
The gauge goes up to 600 PSI, what should I be looking for when I attempt to turn the chain? A drop or a rise in pressure?
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #49
one direction should go higher pressure,
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #50
There are two scenarios that I attempted to show in my attached pictures. The first one is that your gauge is on the "low side" of the loop and stroking the pump will result in a slight decrease in charge pressure. The second is that your gauge is on the "high side" of the loop and that will result in the pressure increasing when you stroke the pump. Depending on the pressure required to turn the motor, it may exceed the 600psi rating of your gauge.
No change. The gauge moves just above 100 and that's it
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #53
R8
Can you physically see the control shaft on the pump? It should rotate approx 15 degrees either direction from center.
Yep, it moves. I can see the shaft moving. Both directions, no difference. It is low on fluid, so I am going to add more before I condemn it, but I have a feeling the issue persists. Is it possible that the lever isn't turning the shaft enough? Like it is staying in between neutral and forward/reverse. I am waiting on a new control cable, hydraulic fluid, a tire and one hydraulic fitting. Once I get all of my supplies, I will give it another go. Right now the machine is in my shop and I would prefer to test everything outside. I also pulled the thermostat out and it was pretty plugged up. I want to get the cooling system nice and clean as well since there is a HUGE oil cooler in front of the radiator and I'm sure that plays a role in keeping the fluid in good shape.
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #55
So there is only 2 possible explanations to what you have happening.
1. The pins (12) that attach the shaft (6) to the swashplate (11) have either sheard off or fallen out. This would cause the swashplate to remain in a neutral position, even though you are rotating the shaft.
2. There is a tremendous leak somewhere else in the system.
Are the system hoses from the pump connected to the motor?
If they are, the next step I would do is cap them and try to stroke the pump. I would do this right at the pump so there are no other potential leak paths availble. This is a "dead head" condition so the oil will immediately go over the relief valves which are probably around 5500psi. You should immediately hear the pump whine and the engine should labor. Do not fully stroke the pump since those valves aren't going to be happy with full flow going across them. I would also make sure you take out the 600 psi gauge because in one direction it will be destroyed.
If it passes this test, then the issue points more towards the trencher motor, not the pump.
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #56
Doaaj50,
Since you sound far more familiar with this Sauer unit would both control shaft rotate if the pins was missing on the side being driven?
Does this model have work port relief valves? Just curious since I know some Eaton units had the reliefs in the motor.
If major leak would he see charge pressure or would it drop?
I would say that there isn't a big leak in the system. The reason I say that is there are 3 pumps on the drive plate. The left hand pump runs the excavator and the boom lift of the trencher. The middle pump runs the drive wheel and steering. The RIGHT hand pump, our troubled one, runs the trencher motor and the backfill blade. The back fill blade does NOTHING. I would think if there was an issue with the trencher motor, the blade would still work and vice versa. My question is, should I wait to try the system again with all the oil, or should I go back and remove the oil that is currently in the system and pull the pump out to check for the pins? Are they roll pins? Do they commonly shear or fall out?
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #58
Is the backfill blade operated via a hydraulic cylinder? If yes I highly doubt it is driven by a hydrostatic pump. Hydrostats require a closed loop flow path where oil flows from the pump to the consumer typically a motor and from the motor back to the pump with equal flow rates. A single rod cylinder does not provide equal flow rates from rod end to cap while operating. You would also have to incorporate a diverter valve to operate either the trencher motor or backfill blade.
So, my assumption is that the pumps operate a number of things, but can't do it all at the same time. There is NO DIVERTER valve. Was it removed? I have no idea. Perhaps someone declared the trencher 'dead' and decided that it could just be used as an excavator and took hydraulics out? The backfill blade has a 3 spool control, none of the controls do anything, but the lift trencher lift cylinder does work and it is plumbed on that same side. If a diverter valve is missing, where would it pull hydraulic pressure from? The left hand side pump? If so, then I assume you are splitting from backfill to trencher lift cylinder. However, I still have the issue of the trencher motor/pump. Is there a way to test the motor in place?
/ Case DH4B Trencher/Backhoe Won't Spin Trenching Chain #60
Any idea on what style or brand of motor is on the trencher? Depending on style there may be tests that you can do.
I think you either need a hydraulic schematic or will have to start tracing hoses on the pump in question. At this time We are just guessing or speculating on how it is plumbed.
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
Ford 8210 (A60462)
Ford 8210 (A60462)
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2016 Deere 180G (A60462)
2016 Deere 180G...
4020CFL (A59228)
4020CFL (A59228)
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
