OP
r8f1k
- Joined
- Jul 21, 2018
- Messages
- 298
- Tractor
- Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
I have tested the pump with a pressure gauge, it holds 100 psi, it simply shudders between 80 and 100 psi when the lever is pulled to engage the trencher motor. The type of pump in post 89, is VERY similar to the pump that is in the unit currently. I am wondering if I could simply re-plumb the system with a simpler system of just a pump and a bidirectional control spool for the motor. I have plenty of hydraulic hose and my own crimping machine. I would also skip trying to use the backfill blade, I would take it off and eliminated it altogether. If someone could help me determine what kind of pump to swap in and what kind of spool would work.
