OP
r8f1k
- Joined
- Jul 21, 2018
- Messages
- 196
- Tractor
- Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
The pump is 23.72 GPM @ 2000 RPM. I went with a large GPM thinking that the flow can be controlled via the spool should it have a flow control feature. I am looking to error on the side of more GPM since it is a cheap foreign made pump. The motor that turns the trencher chain, is VERY large. Its about the size of small car battery. I can't find the GPM on the old 18 Series pump, so again, I would rather have a little more pressure that I can turn down, than not enough. My logic may be flawed, given I have NO real hydraulic experience, just what I know through working on tractors, skid steers, forklifts, etc.....Most of the time it is a matter of swapping an old part for a new matching unit. This is an attempt to get 50% of the machine working in a respectable way that I can trench here and there as needed. It won't be used every day 5 days a week, so I am good with some imperfect solutions.What kind of pump did you purchase or is the 8.4 GPM & the 23.7 liters per minute? Reason for asking is usually flow at an RPM is fixed number for max.
Flow required depends on the hydraulic motor size and desired RPM of that motor.
I appreciate all of the advice over the last couple months, without communities like this, I have often wondered how many other machines would sit DEAD or inoperable simply because the owners don't know how to repair them. I am very grateful to all of the members here who have spent time and effort to help me find a solution to a fix a machine they will never use. I find it so humbling that I am able to post a question and DECADES of knowledge is available simply by pounding a keyboard. I thank each and everyone of you, I am sure many of you have had a few moments reading my responses and have wondered "what the hell.....?". I thank you for allowing me to learn what I have learned so many times from each and everyone of you. The process of talking about the problems and attempting to find a solution, pushes me to keep going. Thank you again!
