Case 310g rescue
/ Case 310g rescue
It has a bit of blow by and smoke under heavy load. Runs like a top tho. I imagine the rings are mostly toast. I will run it a bit this summer and see and plan for a winter rebuild
/ Case 310g rescue #13
Congratulations, that's awesome! I've never really seen such a contraption... since it's like a cross between a bulldozer and a backhoe, could you call it a "hozer"?
/ Case 310g rescue #15
Could be rebuild time.... would that have run non-detergent crankcase oil originally ?
I'd be inclined to run it some more this summer too.....at least one more oil change.
Rgds, D.
/ Case 310g rescue #16
Hozer was the Canadian version ;)
Rgds D.
/ Case 310g rescue
New nickname, i like it
Re; running
I ran it 2 hrs today and also power washed the grime off of it. I am gonna change the oil again as there was some crud in the pan and I want to see if I can get it out. At idle just some huffing from the breather, only in top gear to I get some smoke from exhaust but it does appear to be black not blue. Will see,
I do have a battery question
It is positive ground and the negative of one terminal runs to the negative of a second battery then onto the starter, electrics etc. the first battery has the positive to ground, second= nada
Seems odd that second battery is only hooked at one terminal?
/ Case 310g rescue #18
Sounds like the second battery is not in use... It can't work without both terminals connected.
Aaron Z
/ Case 310g rescue #19
Re; running
The Case listing I could find showed a gasoline motor - is that what you have ? Would work in diesel too, but I'd try a dose of Seafoam in the fuel and also crankcase oil for sludge. Might just take some more exercise to clear out the "cobwebs".
Sounds like somebody had been monkeying with the wiring. System is 12volt ? Could be just a dual battery setup (two in parallel), or are the batteries 6 volt ? May not be as bad as sorting out old RV wiring that has been modified..... but may take some detective work....
You are still using the boostpack to start is my guess....
Rgds, D.
/ Case 310g rescue
It is diesel
Has twin battery boxes, does not appear molested so I am not sure?
Agree w the sea foam
It makes plenty of power and cycles well though the rpm range.
Upper range will keep the mosquitos away I guess
I love having a dozer with a gas pedal(has both hand and foot pedal throttle control).
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
TANK MANIFOLD (A58214)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
