Carrying stuff
/ Carrying stuff #1
hayden
Elite Member
VT
Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
I'd love to hear (and see pictures!!) of what people have come up with to carry stuff on their tractors.
There have been some great notes on ways people have attached tool boxes, and of course the magnetic coffee cup, but what about ...
- A chain saw? Has anyone rigged up a way to carry one?
- Chains? Mine sit on the operators deck and eventually get in the way of the control peddles.
- Misc hand tools like shovels, clippers, rakes, etc.
I'm primarily interested in ways to carry such things WITHOUT impeding tractor operation in any way, so throwing the rakes and shovel and chains and chain saw in the loader bucket the way I'm doing it now doesn't count.
/ Carrying stuff #2
I'm with you-- some kind of carryall is needed. I'm working on a design for a trunk that will mount on the 3 pt hitch. Easy on, easy off, removable rainproof lid, capable of carrying tools or it could be filled with concrete blocks to act as ballast while using the FEL. Cost should be less than $100. Anyone interested in one?
/ Carrying stuff #3
I put a deck and sides on my box scraper. It holds about 800 lbs of rocks. Any tools I want to carry just sit ontop of the rocks. I'll try to get a picture of it.
Peter
/ Carrying stuff #6
Saw this one, and thought it wouldn't be too hard to make....and pretty reasonable to buy also depending on whether shipping is an issue. Not weather proof at all, but I'm not sure I would want a permanent lid. I like the photo with the rough tote plastic box attached.
Rear Carrier
Kevin
/ Carrying stuff #7
I'm with you. Saw a neighbor who mounted big hooks on his ROPS to carry his towing chain, but removing the chain was a pain since it always seemed to snag his SMV or 3pt implements. Also saw a fellow who carried a shovel back there using a ROPS-mounted rifle rack and some bungee cords.
The thing I'd most like to carry would be my chainsaw. I've seen pics of a chainsaw holder for ATVs, but it doesn't look like it would mount to the ROPS very well without serious mods.
Pete
www.GatewayToVermont.com
/ Carrying stuff #8
I echo the sentiments of you all. I've only had my BX 2 weeks but I am always in need of a place to carry a chain and a tool or two. I'm not an engineer so I'd like to "capture" someone else's solution. What are you BXer's doing?
Gerry
/ Carrying stuff #9
Here's the approach that works for me (see series of 3 photos in this and related posts). I have the equivalent of a "pickup" box that I carry on pallet forks. The fork frame also has removable racks (yellow and black) on each side to hold shovels, rakes, pitchforks, etc. For loader ballast, I always have several old wheel weights in the box. When hauling loose materials such as mulch I take them out. The box is very handy for carrying tools, firewood, fuel cans, slings, etc, and I keep it on the tractor most of the time. The forks and tool racks were manufactured by a company called Attachments Plus in Michigan. Not sure they are still in business, but any pallet mover or carryall could be the starting point for fabricating your own pickup box. I built my box as a flatbed with removable sides. Hope this provides some ideas for your own inventions.
/ Carrying stuff #10
Photo of typical "stuff" I carry in the pickup box.
/ Carrying stuff #11
Box removed from pallet forks.
/ Carrying stuff
What are the yellow vertical holders made from? I've been thinking about doing something along those lines, but attached to the loader posts (the one the loader control is on top of).
/ Carrying stuff
Great suggestions. I see lots of use for a 3PH carrier, although in my case I'd like to keep both of the business ends of the tractor clear.
Two specific cases I'm trying to solve are when I have either the chipper or logging winch on the 3PH, need to keep the loader available for shoving brush/trees or leveling the dirt/road, and I want to carry a chain saw, a few work chains, and maybe a pruning saw or clippers. This is what a typical brush clearing or tree removal adventure would look like. However things get mounted, they ideally wouldn't hang out beyond the current tractor extremeties so I don't get more tangled up than I do already.
I've been eying the ROPS bar and the two main stanchions for the loader frame, expecially the space between the stanchions and the tractor itself. I once tried attaching a length of 4" PV pipe to the stanchion but my mounting didn't work too well and I didn't pursue it further.
I might try the pipe thing again. I'm also thinking that a mini milk crate attached to the loader frame woudl be great for chains, rops, and other stuff. Then a pipe or two for thinks with handles like pruning saws, clippers, and even for a chain saw (slide the bar into the pipe).
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
Cowboy Statue (A64557)
Small Cowboy Statue (A64557)
Small Cowboy...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Mayrath 30' Auger (A66285)
Mayrath 30' Auger...
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
