Caroni Flail Belt Failure
   / Caroni Flail Belt Failure #101
Is it possible that the places where the belt is making contact with the pulleys are not smooth? I haven't checked mine yet, but if there were rough spots it might generate the extra heat and belt wear.
Also, do we have a count of how many TBN folks have a Caroni and how many of them are having issues versus not having issues? I'd be interested in knowing the number of Caronis, model #s, # of hours and any issues encountered. I'm happy to compile this information confidentially and post the summarized result if anyone wants to participate in the unofficial survey. Just send me a PM if you want to submit your info.
Dave
   / Caroni Flail Belt Failure #102
Foozle said:
Also, do we have a count of how many TBN folks have a Caroni and how many of them are having issues versus not having issues? Dave
Hasn't there been only one failure reported on this thread? The rest of us are just checking out issues like proper belt tension and normal heat patterns. I certainly have not had any failure.
   / Caroni Flail Belt Failure #103
1 failure
300 trying to help. :D
The only failure I have with the Caroni Flail Mower is that I don't own one as of yet... but I will. :D
Foozle, Grapeman had early belt failure. I seem to remember one other member had a belt problem???
Gates does not make a Kevlar B43. They have PB42 and PB44.:mad:
   / Caroni Flail Belt Failure #105
Dave
Unless grossly rough, pulleys smooth themselves out in the first hour or 2 or use.
One of the most common design flaws in a belt and pulley system is small pulleys,,, especially with a lot of belt wrap. Does the Caroni have any pulleys smaller than ~3"?
   / Caroni Flail Belt Failure #106
No. The smallest is perhaps only a bit more than 3" but I'm pretty sure it is not smaller than that.
   / Caroni Flail Belt Failure #107
One other question. I'm not sure I was always careful early on when engaging the PTO to have the engine at an idle speed. If the PTO were engaged at a high RPM could that cause a shock to the belts and potentially damage them?
   / Caroni Flail Belt Failure #108
I imagine yes but it would also potentially damage other components of the mower and the tractor itself. Idle speed for PTO engagement always.
Foozle,
Not an answer but I learned about low RPM before PTO on from the fine folks here at TBN.:D
I have always been at idle before engaging the Caroni so that rules out that cause in my case.
   / Caroni Flail Belt Failure #110
For a flail the inertial load is so great I prefer to just shut off the tractor, engage PTO, and then just start it with pto in gear. Starter spins it up quickly for a nice graceful start w/o use of the pto clutch. Not sure if this would be a problem with HST tractors, but mine are gear.
larry
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A58017)
1999 INTERNATIONAL...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
