Capacitor on pump control went bloohey
/ Capacitor on pump control went bloohey #1
OkeeDon
Veteran Member
I recently had a 4" well drilled on my Okeechobee land, along with a 1 HP submerged pump. I have it hooked to Hudson float valve in my pond in order to keep the pond at a constant water level. It flows about 25 gallons/minute. After 3 days of constant running to get the pond full, it settled down to an hour or two every other day or so to keep it full. It hasn't been used for anything else.
Power is supplied by a 20A, 240V breaker in a subpanel, which in turn is supplied by a 30A, 240V breaker in a garage about 150' away. Wire size is 10-2 w/ground NLM, buried 24" deep in a trench. My water contractor said that the 20A breaker was sufficient for the 1 HP pump. The breaker is connected to the pressure switch, which in turn is connected to a Franklin control box.
My son-in-law called and told me the pump wasn't running. I ran out there today to check it out. All of the breakers were on, and the pressure switch contacts were in the closed position, but the pump wasn't running. I verified that it had power as far as the pressure switch, then I opened the control box.
What greeted me was a gooey, gloppy mess that leaked out of the capacitor. I cleaned out the glop, took that part of the control box to the water contractor, and he simply handed me a new one. I slipped that on, and everything came back on and worked just like new.
I don't have any idea what could have caused it, and neither does the contractor. It could have simply been a defective capacitor, or it could have been caused by something in the pump or the wiring. We were guessing at things like a power surge, a lightening strike (although there has been little rain and no thunderstorms of which I'm aware), etc.
Our plan is simple -- we're just going to wait and see if it was a one-time thing, in which case it was probably a defective capacitor, or whether it happens again, in which case we'll investigate further.
But, I'm curious. Does anyone know anything about these things, and have any idea of what happened?
/ Capacitor on pump control went bloohey #2
Don, the start capacitor is typically what goes. I have replaced them on well pumps and heat pumps. A simple $2 part is responsible for a lot. Capacitors seem to have a higher failure rate then most other electrical componets. They are typically wet capacitors. It is a fine line between 100% good and 100% bad. I would venture to say you had the latter and it did what they do, rupture. I suspect your going to be OK.
/ Capacitor on pump control went bloohey #3
I agree with RaT about the life of a capacitor. It is not uncommon for capacitors to go bad. The usually swell and leak when they go bad. The only thing I have found that helps the lifespan is to reduce the amount of heat that is around the capacitor. If it is in an enclosed case make sure that there are some air vents so that you can get airflow across the capacitor.
/ Capacitor on pump control went bloohey #4
Don, I regret to say that I know a lot about them. I had a 2 HP 220 volt, single phase submersible pump on my well and have experienced this many times at my old home. It is a result of a lightning strike somewhere along the aquifer that your well is drawing its water from. This sudden surge of "power" will blow out the capacitor and the only remedy is to have spares on hand. At my old home, this would happen a couple of times a year and sometimes, it would actually blow out the pump also. The good news is that it is covered by your homeowners policy if you loose a pump as a result of lightning, or at least if you are in CT. I have a spare relay and also a spare thermistor, but have never had to replace that one. At my new home, I have a surge and lightning arrestor on the electrical panel, and have not had a problem but twice in 20 years, and never since putting on the arrestor. I remember reading about a kid that was playing ball in Florida that was killed by lightning because of a storm that was far away. They later installed some high tech device that would give early warning when the ground wasn't safe to play on because of this tragedy. I don't remember all the details, but I think that it was a Little League game.
Here is an interesting article on lightning and its effects..... web page
As a side note, one of my Weimeraner's name was Lightning!!!!! /forums/images/graemlins/smile.gif
/ Capacitor on pump control went bloohey #5
Don I have had to replace a few. (maybe 3 in 15 years) were I am at. I think the heat here in fl gets to them also because every one that I replaced was in June or July. I keep an extra one.
But yours should not have been from heat this time of year.
Does anyone know if cycling the pump on and off affect them. I was told one that that it did and I bet Don's did that a lot filling a pond
/ Capacitor on pump control went bloohey #6
Cycling should not be a factor since it would be almost impossible to cycle it that quickly to cause a capacitor to go bad. It could very well just have been a weak capacitor to start, developed a short and being in a sealed container, heated as a result and burst open. When little we used to blow capacitors up by attaching them to a extension cord and plugging it into 120V.
/ Capacitor on pump control went bloohey #7
DON,
even though you are running with no. 10 wire, you have a
run of 150 feet. there may be enough voltage drop to make
a difference. i suggest you check the voltage at the pump,
if this is possible, when it is running. if the drop is more than
10%, this could be the cause of your capacitor failure. then
you would need a larger wire size. ouch! i would keep a supply
of these on hand, in case it happens again. these capacitors
can be bought for just a few dollars.
good luck with your projects.
accordionman
william l. brown
wright city, mo.
Good suggestion. I was concerned about that, but stayed with #10 wire to hold the costs down. Going to a bigger wire size, or living with a slight drop for a while, isn't really a problem. You see, I'm cheating. This wiring run is temporary, coming from my son-in-law's garage next door, until we can get our own power. I can get a temporary meter as soon as I pull building permits, but have to pay for it. My plan is to use the power from my daughter's place, along with my generators if needed for construction, until we get our Certificate of Occupancy and can get a permanent meter.
It's a trade-off -- later, I'll be tossing this temporary setup, but I'll save by not paying for the temporary hookup from the power company, and I can use my well in the meantime.
My kids have two meters -- one for the house and one for the garage, and I'm coming directly off the breaker box for the garage, which we just had installed, so I'm not over-taxing their power. I'm just giving them the $$$ for their second power bill until I unhook, so it's a win-win for both of us. Later, my s-i-l plans to do some extensive outdoor lighting, etc., from this meter. When we had the meter installed on the garage, I had the electrician install a 50A breaker for my tig welder and a 30A 120V breaker for my motor home, so I'll be using most of the juice, anyway. It's handy to be next door to family.
/ Capacitor on pump control went bloohey #9
Don, what is the operating current of the pump at 240V. Being 240V and only 150 feet away, I think you will be within voltage drop maximum.
I guess you're asking about the amperage; I don't know. I never saw the pump before it went into the well casing, don't even know what brand it is. It's 1 HP @ 240V single phase; my water contractor said to install a 20A , 240V breaker and I did, in the subpanel about 5' from the well. I wanted to be sure I had enough current (as long as the wire could handle it), so I installed a 30A, 240V breaker in the main panel, 150' away. The tables I looked at, at the time, said the #10 wire could handle the current at that distance, although there wasn't much margin. I would have had a greater margin with #8 wire, but there was a pretty good price jump between #10 and #8. If the installation had been permanent, I would have gone with #8, just to have the extra margin.
/ Capacitor on pump control went bloohey #11
Don:
Capacitor life is affected mostly 3 factors. First is voltage. There is a rated voltage for a cap. Exceeding that voltage can cause a breakdown in the dielectric (basically an insulator). This usually results in a catastrophic failure, as the breakdown allows excessively high current, and therefore heat, which causes the internal paste or liquid to build up pressure. There is a small rubber rupture type pressure relief, but if it is a major breakdown the pressure will be beyond the relief's capacity and the end of the cap typically blows out.
Second failure is due to overtemp. Wrong cap rating or too frequent high current (from frequent starts) will cause an overtemp (higher than rated average current). This results in either a catastrophic failure or a gradual degradation as the internal fluids dry out. Eventually there will be a breakdown, or it may act like it is opened and the cap is useless.
The last common failure is due to aging. As the cap ages, the fluids slowly dry out due to evaporation and a tiny bit of gas leakage (the case isn't perfectly gas tight). The aging is accelerated by thermal stress. Again the failure could be catastrophic or just a loss of function.
Your short life failure is most likely just a defective part.
paul
/ Capacitor on pump control went bloohey #12
Don..... you have me confused..... Is the wire to the well the one that is 5 feet from the sub panel and is that wire a #10 and that you were being conservative to save on the cost of that wire, or is it the entire length of wire from the well casing to the pump that you were conserving on? The pump drop wire will will not change when you change over to your own electrical service, but only the wire from the panel to the well casing. Usually, there is a electrical box mounted on the side of the well casing where the connections are made from the electrical panel joining up to the wire from the pump. The reason for this, is that you have to break this connection any time that the pump is removed from the well. If you skimped on the drop wire, that is false economy in my opinion. I would see the pump installation as a permanent event, and the wiring to the well casing as temporary? I don't understand why you would change the pump wiring at a later date.
That's OK, I confused meself when I wrote it. Here's the sequence. 30A 240V breaker at the main breaker box, just on the other side of the meter, 100A panel, with only a few circuits in it. #10 wire out of the panel, across the attic and down the side of the garage, and about 125' underground, then up about 6' to the subpanel. Total length, 150' give or take a couple. Underground rated wire, in plastic conduit where exposed, but run 24" under ground without conduit.
Subpanel is outdoor rated, mounted on plywood panel, which in turn is mounted on 2 - 4x4 posts. I forget the actual rating of the subpanel, around 50 or 60A, will handle up to 4 full size breakers. Only one breaker in it, now, a 20A 240V. I bought a pre-assembled whip, #10 wire in a plastic flexble conduit with sealed ends, to go from the breaker to the pressure switch, 6' long. Then, a short piece of flexible plastic conduit and #10 wire from the pressure switch to the control panel which houses the staring capacitor, about 30" long.
I planned to stick at least one 20A, 120V breaker in that subpanel, leading to a duplex outlet mounted on the plywood, so I can plug in a power tool, etc., but haven't done it until I can measure available current when the well pump is running. According to the tables I looked at when I installed it, the #10 wire carrying the 30A from the main breaker to the subpanel should have enough juice at the end of 150' to run the well pump. I don't think it will lose 10A in that distance, but even if it did, there should be 20A left to supply my one breaker at the pump. None of the breakers has tripped, and the wires don't get warm. even if the pump has been running for hours.
All the material that came with the subpanel and the control panel indicate that the #10 wire from the nearby breaker in the subpanel is more than adequate. I wouldn't change that; it is permanent. It's the 150' of #10 wire running from the garage where I would have used #8 if it was permanent; that definitely would have given me enough juice at the end of the run to operate a couple of outlets in addition to the pump. As it is, it's marginal, I believe. I'll probably still install the outlets and only use them when the pump isn't running. The most they will be used is for a circular saw of for chargers for battery operated tools -- I always keep spare batteries plugged in.
The failure I had was the paste leaking out of the capacitor; it didn't totally rupture or blow out the end. It's mounted to the cover of the control box panel, and I've placed my hand on the outside of the metal cover when it has been running for at least 30 minutes straight; the capacitor is only 1/8" away on the other side of the cover, and the cover has not been warm.
Excessive starts are unlikely; when the pond level drops, the float in the Hudson float valve drops, and the pump runs continuously until the water level rises enough to push the float closed. The pressure switch is set at 30-50 psi, and when the pond float valve is open, it runs steady at a continuous 35 psi, meaning it never builds up enough pressure to turn the pump off. The pump is supposed to be capable of 25 gpm; the well had a tested capacity of over 60 gpm. The pump feeds a 1-1/2" pvc pipe which runs about 650' to the pond, where it chokes down to a 1" pvc pipe and shutoff valve, because the Hudson float valve has a 1" inlet. The float valve is rated at 65 gpm and 130 psi, so at my theoretical max of 25 gpm, I'm not pushing it. 25 gpm is 1500 gph, or 36,000 gals per day, and according to my rough calculations of area, that's just about exactly what it has been feeding, before the pond reached the level I established for it.
After that, as best as we can tell it runs a couple of hours per day, max, to maintain the level. Florida ponds are water table ponds, without liners or clay sealers, and I expect to lose water every day through seepage back into the ground, unless it rains enough for the water table to reach the pond level naturally. Due to the heat and breeze, I also lose water to evaporation, but I haven't bothered to calculate how much.
I've been doing some other digging around, and I tend to agree with those who said I just got a weak capacitor in the first place. It failed after only about 3 weeks of use.
The proof will be in the pudding -- I didn't change anything after I installed the new capacitor. If it fails again in a relatively short time, I'll start digging around for the cause. If not, then it's pretty likely it was a bad capacitor.
Attached is a picture of the pump and wiring setup, in the background is the garage (the blue building on the right) where the main breaker panel is located, on my daughter's property. The pressure switch is located on the backside of the "tree" that contains the inlet/outlet from the pressure tank; the control box that holds the capacitor is mounted to the top of the well casing.
/ Capacitor on pump control went bloohey #14
Most of the amperage draw is only when the pump starts, so I have been told by the pump installers. I have never checked the actual draw of my pump, but I know that it isn't very much. My pump is approximately 300 feet down and the wire from the control box to the well casing is about 100'. If my memory serves me correctly, it is a 12 gauge wire to the well casing and it has been that way for 20+ years with no problems. I believe that it runs on a 20 amp two pole breaker.
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2018 Trail King Lowboy (A61306)
2018 Trail King...
John Deere 5105M (A53317)
John Deere 5105M...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
Chevrolet 2500 Flat bed (A61306)
Chevrolet 2500...
2014 Dodge Journey SUV (A59231)
2014 Dodge Journey...
