Capabilities of M7040?
   / Capabilities of M7040? #1
manitouofthehatchie
I own an L4400 and my dad is now looking at an M7040 Kubota for moving round bales of hay and general work on his cattle farm. He owns a JD 4020 (67 model) but is looking for a cab now. Will the 7040 handle round bales efficiently and safely @ 68 hp? The dealer says it will w/ no problems but I'd like confirmation from someone who owns one or has at least witnessed the tractor performing this feat. It has considerably less hp than the 4020.
Thanx!
   / Capabilities of M7040? #2
I've handled round bales with an M4700 (about like an M5040) with no problems. Even done one on the back and one on the front.
Ken
   / Capabilities of M7040? #3
Depends on what bales you move. Dry hay bales or 4'x4'wet silage, which may weigh up to a ton.. Kubbies arent very heavy for the horsepower. Your 4020 is no comparison, it weighs over 4500 kg where the Kubbie weighs 2800 at most ?
   / Capabilities of M7040? #4
I don't know how much they weighed, but moved 5x6 very large bales with out problem. I will say, the M7040 is light in the rear end. I've loaded the tires and it helps. I just moved and loaded 20 bales just today with it.
   / Capabilities of M7040? #5
The OP didn't specify whether he planned to move the bales with a spear on the 3 pt, or on a front loader.
For any loader work, I highly recommend 4wd, and loaded rear tires.
If using the 3pt, any M7040 (even 2wd, without loaded tires) would handle round bales just fine.
Ken
   / Capabilities of M7040? #6
The M7040 4wd ROPS with FEL/hay spear and filled rears weighs about 7300 lbs. If that's not enough add a cab (700 lbs), cast rear wheels (500+ lbs) or rear wheel weights which can get you up to 8500+ lbs (3860+ kg).
HUSQVARNA RIDING...
Toro Utility Cart (A59228)
Toro Utility Cart...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
Bobcat S740 (A57148)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
