Capabilities of M7040?
/ Capabilities of M7040? #1
manitouofthehatchie
I own an L4400 and my dad is now looking at an M7040 Kubota for moving round bales of hay and general work on his cattle farm. He owns a JD 4020 (67 model) but is looking for a cab now. Will the 7040 handle round bales efficiently and safely @ 68 hp? The dealer says it will w/ no problems but I'd like confirmation from someone who owns one or has at least witnessed the tractor performing this feat. It has considerably less hp than the 4020.
Thanx!
/ Capabilities of M7040? #2
I've handled round bales with an M4700 (about like an M5040) with no problems. Even done one on the back and one on the front.
Ken
/ Capabilities of M7040? #3
Depends on what bales you move. Dry hay bales or 4'x4'wet silage, which may weigh up to a ton.. Kubbies arent very heavy for the horsepower. Your 4020 is no comparison, it weighs over 4500 kg where the Kubbie weighs 2800 at most ?
/ Capabilities of M7040? #4
I don't know how much they weighed, but moved 5x6 very large bales with out problem. I will say, the M7040 is light in the rear end. I've loaded the tires and it helps. I just moved and loaded 20 bales just today with it.
/ Capabilities of M7040? #5
The OP didn't specify whether he planned to move the bales with a spear on the 3 pt, or on a front loader.
For any loader work, I highly recommend 4wd, and loaded rear tires.
If using the 3pt, any M7040 (even 2wd, without loaded tires) would handle round bales just fine.
Ken
/ Capabilities of M7040? #6
The M7040 4wd ROPS with FEL/hay spear and filled rears weighs about 7300 lbs. If that's not enough add a cab (700 lbs), cast rear wheels (500+ lbs) or rear wheel weights which can get you up to 8500+ lbs (3860+ kg).
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2024 Linx UT357712TG (A60463)
2024 Linx...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2005 All Pro L7077 (A60462)
2005 All Pro L7077...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
