Capabilities of M7040?
   / Capabilities of M7040? #1
manitouofthehatchie
I own an L4400 and my dad is now looking at an M7040 Kubota for moving round bales of hay and general work on his cattle farm. He owns a JD 4020 (67 model) but is looking for a cab now. Will the 7040 handle round bales efficiently and safely @ 68 hp? The dealer says it will w/ no problems but I'd like confirmation from someone who owns one or has at least witnessed the tractor performing this feat. It has considerably less hp than the 4020.
Thanx!
   / Capabilities of M7040? #2
I've handled round bales with an M4700 (about like an M5040) with no problems. Even done one on the back and one on the front.
Ken
   / Capabilities of M7040? #3
Depends on what bales you move. Dry hay bales or 4'x4'wet silage, which may weigh up to a ton.. Kubbies arent very heavy for the horsepower. Your 4020 is no comparison, it weighs over 4500 kg where the Kubbie weighs 2800 at most ?
   / Capabilities of M7040? #4
I don't know how much they weighed, but moved 5x6 very large bales with out problem. I will say, the M7040 is light in the rear end. I've loaded the tires and it helps. I just moved and loaded 20 bales just today with it.
   / Capabilities of M7040? #5
The OP didn't specify whether he planned to move the bales with a spear on the 3 pt, or on a front loader.
For any loader work, I highly recommend 4wd, and loaded rear tires.
If using the 3pt, any M7040 (even 2wd, without loaded tires) would handle round bales just fine.
Ken
   / Capabilities of M7040? #6
The M7040 4wd ROPS with FEL/hay spear and filled rears weighs about 7300 lbs. If that's not enough add a cab (700 lbs), cast rear wheels (500+ lbs) or rear wheel weights which can get you up to 8500+ lbs (3860+ kg).
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2024 Frontier FL1061S Hydraulic Flail Mower (A56436)
2024 Frontier...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
