Can't get heat !
/ Can't get heat !
Hey Thumper, sorry it took so long to respond. I just have one shut off at the thermostat and it is wide open. Blew the air through and lots of circulation. I think I need a bleeder. any ideas how I would put one in and were ? Thanks
Kevin
/ Can't get heat ! #12
Hey Kevin,
How old is the Koti, do you have a good radiator cap, if you don't have the pressure it's going to fight you. On my 1066 the heater core is on top of the cab, when we change the fluid we just refill and start her up with the heat on high for about 20 min. I then let her cool off and top her off. I've never had to bleed a hose up on the cab. I like the idea of the fuel pump the guys gave you. I've got two shut off valves and I close them in the spring to help with the AC working. Hope this helps.
/ Can't get heat ! #13
Any chance you can unbolt the heater and set it on the floor of the cab so the heater and lines are lower than the radiator? This will let the air migrate back to the highest point, The radiator.
/ Can't get heat !
Thanks Guys. My Kioti is only 4 years old. Radiator cap seems fine but you never know. A buddy of mine mentioned dropping the heater below the the motor. I'll check both issues out. Thanks again for the help.
Kevin
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
