Canopy angle
/ Canopy angle #1
Taters525
Port orchard wa
None
Just got a canopy for my L3560 and looks like I can angle it up or down. Anyone have any suggestions. Was thinking angle the front slightly up so the rain runs off the back.
/ Canopy angle #2
Are you parking your tractor on a perfectly level surface outside where it will get rained on? *grin*
I doubt angle or not will make much difference in the grand scheme of things. I designed the roll cage top to be parallel to the tractor, rain drainage was not a factor in my design, nor has it made the plywood roof rot out any faster or slower over the last 5 or 6 years sitting out side...
Angle as you see fit, be it aesthetics or rain shed... both have value.
/ Canopy angle #3
Angle it so you can bonk your head on it every time you get on or off the machine. My cab roof is level so I don't have any options for how I bonk my head. Sometimes I miss it entirely.
/ Canopy angle #4
I use mine for sun protection and it's angled slightly lower in the front. Which for an added plus, tree limbs slide up and over the top and don't hit me in the face (mostly). I don't use my tractor in the rain, tears up the yard and I can wait until it dries up to finish whatever. I also, don't have extra lights on my tractor, when it get dark outside, dinner is waiting for me... tomorrow is another day.
/ Canopy angle #6
I put a tractor canopy on my mower. Angled down so tree limbs would go over it:
Big limbs did not go over when mowing around the trunk :eek::
/ Canopy angle #8
I think common sense says angle the canopy down in the direction you likely will be moving most of the time...:)
/ Canopy angle #11
If it’s the factory canopy, unless they changed it since I got mine a few years ago there is a half inch gutter all the way around with holes on both ends. It naturally wants to point down and having used mine in the rain many times I only get wet when it rains sideways. My personal opinion is put it on either way and your going to be ok
/ Canopy angle #12
I like angling it up in front. Like you say, rain won't mostly drain forward that way. An added plus is that you can tell whether a branch will hit it, just go slow and if it clears at first it clears all the way.
/ Canopy angle #14
If you trailer it frequently, the angle will affect how much force the wind will exert up or down on it regardless of which way you park on the trailer
/ Canopy angle #17
Years ago I sold 3 canopy's to the same customer in a little over a month !
Can you guess what his wife was thinking.....
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
10' Livestock Bunk Feeder (A66408)
10' Livestock Bunk...
