Can you hear the block heater when it is plugged in?
   / Can you hear the block heater when it is plugged in? #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
Every time I go and plug my block heater in on my TC30 I can hear it, It sounds like something sizzling (antifreeze!). It is full up - I topped it off a month ago, The fluid color is good, green. I replaced the thermostat and temp sensor a year ago. It does not overheat, the fluid level stays up. I don't see a problem, but I don't like hearing sizzling. Anyone else
have this?
   / Can you hear the block heater when it is plugged in? #3
I always get in close to be certain that I can hear the sizzle. Confirms that both ends are plugged in, the circuit is on and the ground fault protection has not been tripped.
   / Can you hear the block heater when it is plugged in? #4
Used to be able to hear them. Today that's a memory.
   / Can you hear the block heater when it is plugged in? #5
The sizzle is normal.
That;s good to know- I'd hear it and walk away wondering! Thanks.
   / Can you hear the block heater when it is plugged in? #7
Yup, don't worry about that sizzle. I am hoping to hear that very sound tomorrow morning when I plug my newly installed heater for the 1st time!
   / Can you hear the block heater when it is plugged in? #8
Yep , just the heating element coming to life .Quite pleasing when it is cold and you are going to need your tractor .
   / Can you hear the block heater when it is plugged in? #9
Did it work?
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
2018 BOBCAT E50 EXCAVATOR (A52707)
2018 BOBCAT E50...
2016 Dodge Caravan SXT Van (A55853)
2016 Dodge Caravan...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
