Can you hear the block heater when it is plugged in?
   / Can you hear the block heater when it is plugged in? #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
Every time I go and plug my block heater in on my TC30 I can hear it, It sounds like something sizzling (antifreeze!). It is full up - I topped it off a month ago, The fluid color is good, green. I replaced the thermostat and temp sensor a year ago. It does not overheat, the fluid level stays up. I don't see a problem, but I don't like hearing sizzling. Anyone else
have this?
   / Can you hear the block heater when it is plugged in? #3
I always get in close to be certain that I can hear the sizzle. Confirms that both ends are plugged in, the circuit is on and the ground fault protection has not been tripped.
   / Can you hear the block heater when it is plugged in? #4
Used to be able to hear them. Today that's a memory.
   / Can you hear the block heater when it is plugged in? #5
The sizzle is normal.
That;s good to know- I'd hear it and walk away wondering! Thanks.
   / Can you hear the block heater when it is plugged in? #7
Yup, don't worry about that sizzle. I am hoping to hear that very sound tomorrow morning when I plug my newly installed heater for the 1st time!
   / Can you hear the block heater when it is plugged in? #8
Yep , just the heating element coming to life .Quite pleasing when it is cold and you are going to need your tractor .
   / Can you hear the block heater when it is plugged in? #9
Did it work?
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
JOHN DEERE 323D SKID STEER (A52707)
JOHN DEERE 323D...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2025 Electric Scooter (A55853)
2025 Electric...
