Can you hear the block heater when it is plugged in?
   / Can you hear the block heater when it is plugged in? #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
Every time I go and plug my block heater in on my TC30 I can hear it, It sounds like something sizzling (antifreeze!). It is full up - I topped it off a month ago, The fluid color is good, green. I replaced the thermostat and temp sensor a year ago. It does not overheat, the fluid level stays up. I don't see a problem, but I don't like hearing sizzling. Anyone else
have this?
   / Can you hear the block heater when it is plugged in? #3
I always get in close to be certain that I can hear the sizzle. Confirms that both ends are plugged in, the circuit is on and the ground fault protection has not been tripped.
   / Can you hear the block heater when it is plugged in? #4
Used to be able to hear them. Today that's a memory.
   / Can you hear the block heater when it is plugged in? #5
The sizzle is normal.
That;s good to know- I'd hear it and walk away wondering! Thanks.
   / Can you hear the block heater when it is plugged in? #7
Yup, don't worry about that sizzle. I am hoping to hear that very sound tomorrow morning when I plug my newly installed heater for the 1st time!
   / Can you hear the block heater when it is plugged in? #8
Yep , just the heating element coming to life .Quite pleasing when it is cold and you are going to need your tractor .
   / Can you hear the block heater when it is plugged in? #9
Did it work?
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
1839 (A57192)
1839 (A57192)
Mini Margaritaville Truck (A55853)
Mini...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
