Can you hear the block heater when it is plugged in?
   / Can you hear the block heater when it is plugged in? #12
So....what actually causes the sizzling? I am always grateful to hear it, as it confirms my heater is doing what needs doing!
   / Can you hear the block heater when it is plugged in? #13
Must be the water in the coolant boiling on the element. Since the engine is cold, the system pressure is at atmosphere. So the heating element at 212 degrees or so boils the water.
   / Can you hear the block heater when it is plugged in? #14
Mine sizzles... I do have it connected to a 110 Volt plug that turns on at 32 degrees...
   / Can you hear the block heater when it is plugged in? #15
Coolant doesn't boil at 212 degrees. It's higher. I once considered a heater for my little tractor, but down to 10 degrees above, the glow plugs have always done the job. I do get the occasional ice or gel, but that's a separate issue, mainly from my not keeping the tank topped off all the time, which is not a good thing. The fuel filter on the 26 is way too small, else even that would be very rare. Below 10 degrees it would probably start, but since I use 15-40 oil all year, that's the recommended limit, I think. And below 10 with any kind of breeze is a little too nippy for me on an open tractor.
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
