Can my L3940 handle a JD MX7 cutter?
   / Can my L3940 handle a JD MX7 cutter? #1
beppington
Elite Member
of my
Here
7 footer.
There's one for sale locally, says excellent condition (aren't they all?!) ... haven'y seen it yet.
But will my 3-ton, 40.5HP, 31.5HP PTO tractor handle it, or is it just too much?
I don't try to bush hog 2"+ diameter trees (I saw those down), but I want to be able to mow heavy stuff & beat up saplings up to about an inch, maybe a little more. And of course I don't want to kill my tractor if this thing is way too heavy or just overall too much for the PTO.
Also, they want $2,600.
What do you all think?
   / Can my L3940 handle a JD MX7 cutter? #2
Well the general rule of thumb is 5 PTO hp per foot of mower. Might be ok on light stuff but it will be working hard in heavy stuff.
MarkV
   / Can my L3940 handle a JD MX7 cutter? #3
I think the bigger problem will be all that weight hanging off the back of the tractor. If you are not careful, the tail may wag the dog!!
   / Can my L3940 handle a JD MX7 cutter? #4
I run a Land Pride RCR2672 on my L5030 and while it will power a RCR2684, I have all the weight I really want on there now. I am not familiar with the specs on the John Deere, but they look like really good pieces of machinery.
I personally like a cutter no wider than my rear tires or much wider, otherwise I wind up hooking something like a tree with it.
   / Can my L3940 handle a JD MX7 cutter? #5
IMO - it would be too much for your tractor - weight off the 3pt as well as the pto power necessary for it to really cut well.
I can recall several comments on the JD forum regarding the MX7 and several were not pleased with the performance of the cutter. Many cited the "spin-up lag" and the power needed to move that big blade up to pto speed.
There were suggestions that if they "knew before-hand"... they probably would have went with an MX8.
AKfish
   / Can my L3940 handle a JD MX7 cutter? #6
Our 6' works our 50 PTO hp tractor pretty good in really heavy stuff. We have
an L3940, I wouldn't put a 7' on it period.
OK guys, thanks for the input. I'm gonna skip it. Seems it'd be too much for my tractor, & I hoped to spend less than $2K ... Plus it's green!!! :confused2: ... :laughing:
My dealer recommends either a "standard" (1" - 1.5" cut) Woods or Bush Hog (both $1,900) or a "heavier" (2" - 2.5" cut) Land Pride RCR2672 ($2,499).
If you have any thoughts on those, I'd appreciate you sharing them ...
   / Can my L3940 handle a JD MX7 cutter? #8
Seven footers are a unique beast. IMO the 5 HP per foot of mower really don't apply here. Being a single spindle, they stick out the back rear far.
There was a thread on TBN somewhere that discussed 6' vs 7' vs 8' mowers. The expert opinion was to either use a 6' or an 8' mower and skip the 7'. I don't remember who the person was, but he had a lot of mowing experience with all the mowers discussed. He said he had a tractor that could handle both the 6' and 8' OK, but was scary with the 7' mower.
Yeah, after seeing a 6-footer in person (noob here) versus my dad's 5' cutter I've been using, I can only imagine how huge 7-footers are.
Since the 5, 6 & 7 footers are single-spindle units, here's the math:
Size...Area (sq feet)
.5'............19.6
.6'............28.3
.7'............38.5
A 6' is 44% bigger than a 5'.
A 7' is 36% bigger than a 6'.
A 7' is 96% bigger than a 5' <-- almost double the area: HUGE (to me anyway)
24220 (A56859)
24220 (A56859)
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
Zero Turn Mower (A59228)
Zero Turn Mower...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2015 Peterbilt National NBT40 Crane Truck (A60460)
2015 Peterbilt...
