Rotary Cutter Rotary Cutters
/ Rotary Cutters #31
As you can see from the picture, the Woods is one heavy duty machine. Even their lightest unit is still a far cry heavier duty than anything on the market. I have a Woods, M5 - Dixie Cutter that is over 25 years old and the only thing I've replaced is the blades. I've split enough rocks to build a fine-looking chimney and still the unit keeps on running. Most of it's life it has sat outdoors so the steel deck is beginning to look a little worse for wear, but it still can cut through anything, and I mean anything. My Dad has a King Kutter 5 ft that although is a fine machine, there is no comparison. The bent I-Beam side rail is a good idea, but the deck material is just too light and has suffered some major dents. I think most of us could get by with a King Kutter, but if you truly want a quality machine, go with the Woods.
/ Rotary Cutters #32
Re: Rotary Cutters-Brown 484
I'm looking at Brown also...about $2400. for the 484 Medium Duty
Extremely hefty 1/2" thick 3-Pt. hitch bracing and lots of thick steel...{about 1375 lbs.}
"You are what you eat, drink, think, say and do..."
/ Rotary Cutters #33
Re: Rotary Cutters-Bush Hog 306
Bush Hog 300 series is similar to Brown 400 series spec's but higher in price...
/ Rotary Cutters #34
Re: Rotary Cutters-Bush Hog 287
Bush Hog 287 has 10 ga. deck vs. Brown 7 ga. deck and higher price...
The fit and finish is superb on Bush Hog...
/ Rotary Cutters #35
The paint job is nothing like Woods or Bush Hog...
Notice the double steel braces up front and on the rear wheel yokes...
/ Rotary Cutters
Cleev,
By the way, I think you had gotten a very good price on your Brown 460...
How do you like it so far?
/ Rotary Cutters #38
John
Checked the weight of the medium duty 5'. At over 1,000 lbs that would be too much for a 2910. The light duty looks a lot like a <font color=green>JD</font color=green> 513. Have you been able to view them at a dealer?
/ Rotary Cutters #39
IMHO, I would rank Rhino the #1 rotary cutter, and the Woods at or near the bottom.
The only cutters I would even consider are the Rhino, Land Pride and Bush Hog.
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ Rotary Cutters #40
John,
Thanks for the heads-up. I checked out the Brushbull page and also looked around at the rest of the site. Looks like they made a few updates in other places too.
I guess most people who buy Woods products probably don't go anywhere near the website, but for nerds like me who like to research these things it is important/w3tcompact/icons/smile.gif.
Rob
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
