Can I pull out invasive willows using my tractor?
   / Can I pull out invasive willows using my tractor? #11
Cheap solution is a brush grubber, they make several sizes - best used with a helper.
Brush Grubber Extreme - YouTube
This is my solution - tree puller
Id the willows are large or have been cut back many time you will find the root structure is huge and deep. I used my BX 25 BH to grub out what looked like a small 4" tree at the surface. Turned out to be a 5' wide hole 4+ feet deep and a stump I could barely lift.
Ron
My willows are along a fence line with the neighbor property. White pvc three rail fence with welded wire fence on my side. Some of the willows grow through the welded wire.
I have a mixture of new growth and old growth willows. There is an irrigation water ditch running through this, and on the side where I can mow I have historically mowed them down using my rotary cutter or walk behind brush cutter. Down in the ditch and on the other side of the ditch is the larger willows, since I have not been able to mow in that area. I have cut some of those in the past with a sawzall, but they come right back. I have not tried painting the stumps with glyphosate.
I don't think its an option to get the neighbor to use his Bobcat on my side. I do have three bucket hooks so I can at least pull three at a time. I will try this on the smaller and medium sized ones and see how it works. I think I'm going to try the sawzall and glyphosate method for the ones embedded in the fence. If I pull those it will tear up the fence.
Any suggestions on make or model of brush grubber? I see there are models that "pinch" and also chains that use a choker method. I don't have one and have never used one.
That tree puller rocks!
I looked at brush grubbers and the chain type looked best for my needs. Every review was 5 out of 5 except one. The one reviewer said he immediately broke the chain. When he tried to get it replaced under warranty the company denied it since he had used a tractor to pull. Apparently the chain type is only rated for a UTV such as a Polaris.
BrushGrubber | Shrub/Clump Grubber Extreme
This was advertised (bucket grubber) as a device to pull invasive plants without ever leaving your tractor. But I couldn't find any reviews or videos about it. I guess because it is new?
BrushGrubber | Heavy Duty Bucket Grubber
   / Can I pull out invasive willows using my tractor? #14
Several wraps of standard chain and a slip hook won't do it?
   / Can I pull out invasive willows using my tractor? #15
Yea I think I'd try the chain with a slip hook.
I have a Brush Grubber BG-08. It does work but it's got to be positioned just right on the stem of the plant. The spring is stiff so it's a bit of a pain to wrestle. The next larger one has handles that would help. For me it's easier and faster to chainsaw the brush and leave the stumps in the ground. The ones that resprout can be mowed down or sprayed.
   / Can I pull out invasive willows using my tractor? #16
I'm going to try that. I have 3/8" grade 70 chain which is massive overkill. But I'm confident I can find some lighter duty stuff to try.
   / Can I pull out invasive willows using my tractor? #18
We have used this Brush Grubber Mini BG-25 with a chain hooked to our Bolt-On hooks and it has worked well in places where I didn't have the room to get the grapple in there and I didn't want to tear out the fence or other items.
   / Can I pull out invasive willows using my tractor? #19
A chain and slip hooks chained to the back of a tractor does wonders, two people makes the process much faster... I pulled out 30 or so grape plants last winter with an old Farmall 130 (loaned out the Kubota) and a chain with the wife's help, I always keep that chain handy for tractoring...
   / Can I pull out invasive willows using my tractor? #20
BORROW YOUR NEIGHBORS BOBCAT, OR OFFER TO PAY HIM TO DO YOUR SIDE. IF YOU DON'T DO THE ONES ON YOUR SIDE THEY WILL SPRED SO HE MIGHT BE INTERESTED.
This. You really just have a king size lawn mower as far as weight is concerned...and its all about weight. Try and get something much heavier.
2003 Big Tex 10PI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
