75 acres of timber with house - trails, small garden, invasive control
/ 75 acres of timber with house - trails, small garden, invasive control
Thanks for all the great input. I visited three heavy equipment dealerships today, Case, John Deere, and CAT. No tractors at any of them, but I think I'm getting a rounded out idea of what might make sense monetarily and practically. Probably need to do another round like this except at tractor-centric. I'm definitely going to register for the local auction, and maybe try my hand there. I saw an ASV Rt30 track loader for $15k locally, it's "only" 30 HP with a bucket... But no title... So that seems a little sketchy. Also still unsure of the compatibility of attachments, and from what the one salesmen said today, you need high flow hydraulics to run a brush hog or other mowers.
The hunt continues!
/ 75 acres of timber with house - trails, small garden, invasive control #42
We had lots of invasives and downed trees on about 4 or 5 acres of our 8.5. The wife took them on with her not going to the gym. With her trusty battery chain saw, she cut down the autumn olives and cut up the downed trees and loaded them into the bucket of the JD 2025R. I piled them from the FEL into gullies on the property. Some are piled quite high now. They'll slowly degrade and become kugllekultur (sp?).
/ 75 acres of timber with house - trails, small garden, invasive control #43
1) I saw a track loader for $15k locally, it's "only" 30 HP with a bucket... But no title... So that seems a little sketchy.
2) Also still unsure of the compatibility of attachments, and from what the one salesmen said today, you need high flow hydraulics to run a brush hog or other mowers.
1) Neither tractors nor construction equipment have titles.
2) Construction equipment uses continuous hydraulic power for implements. Construction equipment often has high flow hydraulic pumps.
Tractors use mechanical power from the tractor Power Take Off (PTO)
to implements. Much more efficient power transfer relative to hydraulic power transfer. Mechanically powered tractor implements such as snow blowers and mowers are much cheaper to purchase than hydraulically powered construction equipment implements.
Hydraulic power on a tractor is used only intermittently so modest 10 - 12 gpm is the norm.
/ 75 acres of timber with house - trails, small garden, invasive control #44
I saw an ASV Rt30 track loader for $15k locally, it's "only" 30 HP with a bucket..Also still unsure of the compatibility of attachments, and from what the one salesmen said today, you need high flow hydraulics to run a brush hog or other mowers.
Thing to look at on skid steers is the rated operating capacity (ROC) as that gives a better idea of useful lifting capacity than the tipping load - and the hydraulic flow.
For many hydraulic motor-driven implements (like mowers) high flow is usually required - there are some out there don't, but it can be very limiting depending on the application since the hydraulic flow is what is providing the HP to the mower/implement ....so assuming a constant max pressure: less flow = less HP
...and with the smaller skid steers (e.g. under 40-ish HP) the ROC and hydraulic flows start to become very comparable to larger frame compact tractors of the same HP ....so the only thing that's really gained with the skid steer is the potentially higher breakout force (mostly useful when digging), and the inherent design features of skid steers (method of turning/skidding, and lift arms being designed for digging/ground engagement).
So for example the ASV Rt30 has a tipping load of 862kg a ROC @ 50% tipping load at 431kg and a ROC @ 35% at 302kg and skid steer brush mowers tend to be heavy. For example this 60" one 60" Wide Brush Mower Attachment 11-20 gpm is marketed as weighing 860lbs which is close to the Rt30's 50% ROC of 950lbs (note this mower is also one where high flow isn't required, but it's still recommend that the flow be at least 11gpm ....and the Rt30 has a max flow of 37.9 lpm (~10gpm).
The other thing that needs to be considered with continuous flow implements is how well the machine can dissipate the heat generated in the hydraulic system by continuously running a hydraulic flow ... particularly if it's going to be for hours on end.
/ 75 acres of timber with house - trails, small garden, invasive control #45
Thanks for all the great input. I visited three heavy equipment dealerships today, Case, John Deere, and CAT. No tractors at any of them, but I'm getting an idea of what might make sense monetarily and practically.
  • Would like to pull logs to a mini sawmill (don't have yet), or onto a trailer for pulling to a neighbors for them to mill.
  • Would like to make some new hiking/ATV/dirtbike trails, and keep existing trails clean
  • Control invasive himalayan blackberry... some in unplanted areas, some amongst seedling trees (might need a handheld brush cutter, like a weedwacker with saw, for this)
  • till small garden
  • grade/flatten the gravel roads
  • maybe plow some snow
Above are applications readily accomplished with a tractor and very common tractor Three Point Hitch implements.
You can certainly do these with construction equipment but accomplishment will take longer and equipment required will be much more expensive.
Industry surveys report that compact tractors average 60 engine hours per year. You may well average 150 engine hours per year. I average 250 engine hours per year. All of these example hours are reasonable for a owner operated tractor.
/ 75 acres of timber with house - trails, small garden, invasive control #46
I was out with my Stihl FS110 yesterday and the scratch saw blade. I still wish it were bigger but got through a few hundred feet of tough brambles, vines and 2-3" thick bushes.
So it is possible to do with just that device and use a weed wacker to keep it down.
Using the tractor and toothbar through the thick stuff and to knock down/rip up some of the brush is faster, but messier and need to leave an exit.
Would be nice to have something heavier to push through, but trying to keep the trees and some buffer between neighbors.
Good luck with your search.
So something I've been reading the last day or so is that the CTLs don't have very good clearance... I guess that should have been an obvious reason for their stability (getting the center of gravity low).
I am just starting to look at the Bobcat Toolcats... they are pretty interesting to start. I haven't got past an initial craigslist search for now.
This is the cutter I ordered... Fedex is telling me that it might be here in 3 days (for a total of 11 days from the time I ordered, shipping from China):
Hopefully it's a decent machine!
I have been whacking at things with my Pulaski every few days, and I'm not disgusted with my progress... it's good exercise, which is part of what I was wanting in buying a big place. The thickets of blackberry are definitely something I'll need at least the backpack cutter for... but it still begs the question of:
A) how to rake all the cut thorny vines into a big pile
B) what to do with the pile after it's collected in one (or many) spots. Would this be burning with one of those half-million BTU torches I saw at the farm store (I guess it must connect to a grill-sized propane tank?)? Or some sort of mulcher (and which one, I'd guess not a normal "up to 4" branches" type)?
/ 75 acres of timber with house - trails, small garden, invasive control #49
Ratchet Rake bucket attachment.
Yes & Yes
/ 75 acres of timber with house - trails, small garden, invasive control #50
I pile himalaya berry vines and canes on a pile of stuff that I don't chip, along with old wood and poison oak I pull out.
Vines don't chip well. The woody canes might but with the thorns it's too much of a hassle.
/ 75 acres of timber with house - trails, small garden, invasive control #51
I put out a proto-wildfire a couple weeks ago that my neighbor set by burning a blackberry bramble (big bramble, breezy day, lots of dry grasses that luckily were easy to cut a fire line in).
Those canes burn hot and fast.
They also almost complete decompose in a year left in a pile with no other composting effort - my advice is either make a small pile to burn safely, or make a big pile and leave it be till next year. It won't grow back once you've scraped it off of the ground.
If you scrape blackberries when the ground isn't dry and hard you'll pull most of the roots with the brambles and avoid most regrowth as well. I got a ratchet rake to do this but for the most part I just use my piranha tooth bar and back-drag, it works almost as well and I don't have to take the ptb off and put the ratchet rake on and then get the ptb back on after I'm done...
Definitely don't want to encourage wildfire!!! Leaving them to rot sounds good enough.
I'll have to learn about ratchet rake, piranha tooth bars, and what a "ptb" is!
/ 75 acres of timber with house - trails, small garden, invasive control #53
piranha tooth bar = "ptb"
/ 75 acres of timber with house - trails, small garden, invasive control #54
Took all of this minus the big trees out with the PTB. Can walk through here now.
Brush moved to piles to break down a bit. Might use the forks to move to another place if needed.
Well I split my efforts... Hired an excavator/operator for a day with his 10000lb machine and flair mower attached where the bucket would be.
Then I bought an old Gravely 5000 series 2-wheeled tractor with brush mower, tiller, and rotary plow. Had to clean the carb and the implements, and the mower deck needs a little welding... But so far other than getting stuck due to no differential lock and "turf" tires which I'm working on finding some proper R1 tractor tires to replace... I'm pretty happy. Not nearly as scary if I risk toppling the machine as something larger and ride-on. Small enough to get past the orchard into the garden area section for soil prep. Just big enough to clear brush from walking trails.
Not sure if it will do much in terms of being able to doze my trails flat... But we'll see how things develop.
/ 75 acres of timber with house - trails, small garden, invasive control #56
The old 2 wheel Gravelys are tough little machines.
Though I don't use it, I still have my Gravely Pro 12 with 30" mower deck.
It has dual wheels,(4 tires) and a steering brake.
/ 75 acres of timber with house - trails, small garden, invasive control #57
If you are thinking about anything except a tractor, I recommend renting it and using first. You will quickly learn the limitations and uses. I think Jeff has it right. 3000-5000 lb tractor Seems like the right call.
However if you want more of a TLB take a look at the Kubota L47 or M62. Expensive but very well built and capable .
/ 75 acres of timber with house - trails, small garden, invasive control #58
RalphPA you have temporary hill mounds now as all
that dead wood will rot and you will have trenches again
willy
/ 75 acres of timber with house - trails, small garden, invasive control #59
The Kubota L47's, and M62's are REAL (mid size) TLB's, not just backhoes added to a tractor!
Wonderful pieces of equipment!
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Sellick S80 (A60462)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2002 Ford Econoline E-250 Cargo Van (A59230)
2002 Ford...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
