Can all tractors flip over easy?
   / Can all tractors flip over easy? #161
Not to turn it back but a "Tunnel Rat" had it a lot harder . . .
   / Can all tractors flip over easy? #162
Oh? Really? Someone in a warzone 50 years ago tasked with going into boobytrapped, jungle, death tunnels had it harder?
You don't say?
I'm 6'5" and weighed 260 pounds at my smallest; tight spaces terrify me, and I'm not too proud to admit it. So, yeah, I have a bit of respect and admiration for people that can squeeze their asses into wells, tunnels, etcetera, whether they're in any real danger or not.
It's almost like we view things through a lens based on our own experiences, and therefore what is and it not impressive might vary from person to person. 🤷‍♂️
   / Can all tractors flip over easy? #163
You don't say?
Okay tacticalturnip, I think . . . most people do not akin to such behaviors, I know I do not, so let's leave it at that.
   / Can all tractors flip over easy? #164
Edv4FJhX0AAPO47
   / Can all tractors flip over easy? #165
Flipping is front to back, rolling is side to side.
I have a ferguson To30 and it's not easy to roll because I have the tires flipped, which gives it an abnormally wide stance. Dragging the box blade is fine because the 3pt is mounted below the axle, so if it gets stuck on something the front wheels dig into the ground, rather than coming up.
My oliver industrial 77 is super easy to roll, because it's center of gravity is so damned high. I haven't rolled it, but I can see how it would be easy to do so.
"Flipping is front to back" so you flipped your tires front to back? :)
   / Can all tractors flip over easy? #166
A Ford 8N will surely plow. But there are safer, easier to operate 10 year old to 20 year old compact tractors to learn on.
Ford 8N Weight
Shipping - no fluids2,410 lbs
1093 kg
Operating2,717 lbs
1232 kg
The compact tractor era functionally began when Henry Ford licensed Harry Ferguson's tractor and Three Point Hitch design in 1939. The tractor industry uniformly adopted the Three Point Hitch after 1955, when Ferguson's patents began to expire and his tractor and Three Point Hitch design were available to industry participants besides Ford open source.
Improvements in approximate order: Power Steering, "live" then "independent" PTOs, Rollover Protection, 4-WD, Industrial Tires, Loaders, later Loaders and attachments with SSQA couplers, synchromesh geared transmissions, Diesel Engines, heavier tractors with Category 2-3-4-5 TPH, TPH telescoping Lower Links + pin-adjustable Lower Link stabilizers, Landscaping tractors of <2,000 pounds bare tractor weight, hydrostatic transmissions, shuttle shift gear transmissions, cruise control, Cabs with heat and AC. And, continuously, shields separating operator from moving parts.
The Ford 8N was largely designed around pulling a 2-14 plow, and a lot of them did just that back in the day. Plowing is why the 3 point hitch was originally designed, before that, if a plow hit a stump or a tough patch of soil, the front wheels were coming off the ground.
The first tractor that was marketed for landscaping tasks and other not-strictly-ag purposes was the International Cub. The Ford N series were absolutely marketed as regular ag tractors and people used them as such.
Of the list of your improvements, this is the order in which they appeared, or very closely:
1. Power steering
2. Diesel engines
3. Loaders (but took a long time to go from being available and occasionally used to being ubiquitous)
4. 3 point hitch (category 1, then shortly after category 2)
5. Live and then later independent PTO
6. Synchromesh transmissions
7. Cabs with heat and A/C
8. Category 3 3-point hitches
9. ROPS
10. Full PTO shielding
11. Adjustable draft links
12. Hydrostatic transmissions
13. Practical 4WD (not MFWD)
14. Category 4 3-point hitches
15. Hydraulic reverser transmissions
16. Widespread use of MFWD
17. Loader QA
18. Pin or tube 3 point draft link stabilizers rather than chains
19. Industrial tires on tractors
   / Can all tractors flip over easy? #167
I’m just a dumb ol‘ engineer
Surprised? That's what you get if you believe the media circus and do not investigate yourself... I'm just an ordinairy guy, did not believe that an aluminium aircraft could penetrate a steel constructed sky scraper build to resist an impact like this and then make it come down like?? well ?? right ! a well prepared demolision, tree times in a row. And the world watched and said: "oh the metal was so hot, it pan caked" yeah sure. Why did survivors hear bombs go off like clockwork before the collapse? Where did the heat come from to melt metal? Kerosine exploded on impact... Think again, before telling me to get help. It simple logic, which you should understand if you're the same type of engineer like I am, and the reason why I love old tractors, cars and bikes...
I’m just a dumb ol’ engineer, who aced all the structures classes, while working his way through college as a bolted steel, and fireproofing inspector, and didn’t become a structural engineer only because I got a lot better offers to go be a construction guy, and build things.
This dumb ol’ engineer knew as soon as the second plane hit, that if they were really lucky, the towers would pancake and not topple. I knew enough about how the building was put together, and that the plane impact it was designed to survive weighed less than a third of the planes which made impact.
You are right that it was a well planned demolition. The bastages who lead that effort were all graduate level architecture students at a polytechincal university in Germany, which also teaches structural engineering. The Towers were a distinct and ground breaking structural system. There were ten chapters in the back of my structures book, which were there so the book could be used as a graduate level text. One of those chapters was on the World Trade Center. The book was printed in multiple languages, one of which was German, and that book was used as a text in universities all over the world. If their classes weren't taught from that book, the library most certainly had at least one copy on the shelves.
I was very familiar with the World Trade Center’s structure because I had done that chapter for extra credit. And, personally I am certain that some engineering student who was freinds with the bastages, had explained how to take down the towers to the architects who ran the operation.
“Explosions”. Have you ever pulled a large piece of iron until it failed? I’ve been in a lab when they tested a #16 rebar to failure. You could feel it from the other end of the building. the instant release of energy destroyed a very expensive machine. The “explosions” were a cascade failure which occurred when one overstressed rod burst, and the instant increase in load to the ones on either side caused them to fail, which caused the ones beside those to fail, all the way around. That would definitely sound like a series of timed charges.
The impact points of the planes were not random.. they were chosen so that the load from the stories above would be enough to initiate a cascade failure once the structural steel cross ties started to stretch. The rolling of the plane to make a diagonal impact over multiple floors was not random. Putting the fuel in the wings into multiple floors would help assure the heat from the flames was spread out.
The sprayed on fire-proofing looks like a cross between paper mache, and hydro-turf, and is actually very easy to break away from the steel. the impact from the plane was more than enough to do it. Architects, and graduate students in structural engineering would know that.
So, please keep your ignorant opinions based on your total lack of real knowledge to yourself. At least, until you learn enough to begin asking intelligent questions, instead of spouting off your unfounded opinions.
   / Can all tractors flip over easy? #168
I think the OP is talking about flipping over backwards. Any tractor can do that but I will say a 70yr old 20hp machine is not the machine to plow new ground with.
Nor a new sub compact...........
Best,
ed
   / Can all tractors flip over easy? #169
Yep, you seem to know everything about it, so you're saying it was indeed controlled demolision and a pancake effect both at the same time. I only should not have written that I don't believe the pancake effect. Okay, the result is still the same.
What I saw was not a raging fire and seen recent other towers burning completely like a torch but not coming down, I say this clearly still remains an inside job.
Apart from all this, I find it beyond believe how the owner could say in an interview the day after "Building7 was so much burned down (hardly flames visible), we decided to pull it." Like every building has a button that says "push here to start controlled demolision" hahahahah what a joke.
I'm just frustrated that "the powers that be" can run a theatre like this in plain view of the world and get away with it and start a war over it that killed even more innocent people.
Bloody hell, this world is so bent out of shape.
   / Can all tractors flip over easy? #170
I do know quite a bit about it. I read the report published by the Engineering Societies, on what happened and how. And have enough background to read it intelligently, and understand most of what they said. I think there were several versions. One dumbed down to a fifth grade level for the politicians, one dumbed down to a high school or college student with a SEM background, one one aimed at Engineers who understand the basics of structures. Very similar to a thesis from a grad student, or dissertation from a doctoral candidate.
I think the impact waves had rattled it enough that the fireproofing had popped off. To repair that to new standards, with new materials, would require gutting all of the interior to get at the steel. And, at theat point it would cost less to demo, and rebuild. The insurance companies probably hired a structural engineering consulting firm, and decided that the demo, was the least costly route.
When you demo most things in an urban environment, you don’t have the property available to make things topple. So, you have to design your demolition to fall within your property foot print. Which is when you design your demolition to pancake, into itself as opposed to topple.
Toppling is easy: Blow out the bottom in the direction you want it to go, down low so it sags that way. Moments later you blow the other side. As it goes from compression to tension, and the building falls where you want it. At least in theory. Tons of stuff on YouTube of it going wrong.
Designing a pancake is considerably harder. You design the blast pattern to start collapsing the building from neat the top, into it’s interior to contain your debris mostly in the building footprint. As the debris falls you time more blasts to help things break into the interior, and eventually the momentum of the falling debris gets high enough you don’t need any more charges, and the building takes itself down to the inside.
Designing, the aircraft impacts, to be at the right place, and generate enough heat, that the stay rods in the interior would stretch enough to let them expand just enough that the load from above, and outward movement of the stressed skin, would generate enough force to drop the buildings was a very complicated undertaking on demolition design.
Unfortunately, in a far less “secure” world, we essentially delivered the structural niceties of the towers to them, in the way of a text book which had enough information in it to allow the analysis required.
   / Can all tractors flip over easy? #171
1. Power steering
2. Diesel engines
9. ROPS
17. Loader QA
Many drawbar hitch implements had quick release couplings.
   / Can all tractors flip over easy? #173
Thanks Jigs, for taking the time to describe and explain. I regret however that you do not react to any other of my other remarks. I saw an animation of what should have happened if a plain crahsed into a steel tower/concrete skyscraper and again this convinced me what a load of b.s. this whole official story is, not even speaking of the war on innocent people that followed.
Maybe better to stop here. This has nothing to do with tractors... :unsure:
   / Can all tractors flip over easy? #174
Can we get back to the discussion we all came here for?
I'm sure there are forums where somebody cares about your 20 yr conspiracy theory - but this isn't it.
   / Can all tractors flip over easy? #175
Can we get back to the discussion we all came here for? I'm sure there are forums where somebody cares about your 20 yr conspiracy theory - but this isn't it.
You didn't read my last line...
   / Can all tractors flip over easy? #176
Can all tractors flip over easily?
No, sometimes you really have to work at it.
   / Can all tractors flip over easy? #177
I'm a quick release coupling. 😏😏😏
You surely can be. It’ll take less than two second‘s to disconnect you from your Tractor.
   / Can all tractors flip over easy? #178
I thought about buying an older tractor like an 8N, but then I started reading about them flipping over. I'm sure you can use common sense be pretty safe, but I got to thinking that maybe all tractors could flip? Was looking for advice on safety. I was thinking I probably need a sub compact now because they look safer, but I could be fooling myself.
I started driving one of the 8N’s we have when I was 11. Probably the most dangerous incident that has occurred in the 39 years since then was ~ 20 years ago mowing dow an old trail where someone had left a stump short enough vegetation could grow over it to make it not visible but not low enough it could be mowed over.
Rear tire climbed stump tilting the tractor then it hit them it stopped instantly as the long came between the tire and bush hog. The steering wheel became a “seat belt“ at that instant with a little bruising. I cut that stump off flush as well as any others since or leave them closer to 4 ft + high so they are not low enough to become camouflaged.
Neither of the two we have have been rolled, that said none of the other tractors we have have been rolled either. Including the tricycle Farmall Super MTA, that is really intended more for row crops than what we use it for. Much higher center of gravity and being a tricycle like the killer ATC’s that were banned in the US back in 86-87.
I am not sure one could ensure they never roll a tractor because I have seen some folks that could break an anvil with a rubber mallet but being scared of being hurt or killed goes a long way towards making the right decisions. Many “accidents“ happen to people that really know better and just take risks that are needless. If any activity is recorded, you can bet someone didn’t think was safe.
   / Can all tractors flip over easy? #180
Talk about slammed!
2019 Ford F-350 (A55973)
2019 Ford F-350...
PENDING SELLER CONFIRMATIONS (A59904)
PENDING SELLER...
2023 BOBCAT E88 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E88...
207272 (A52708)
207272 (A52708)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2018 ROSCO LEEBOY CHALLENGER 7 SWEEPER (A60429)
2018 ROSCO LEEBOY...
