Cab in progress
/ Cab in progress #42
DDT,
I don't have a desire for a cab myself...BUT...
I keep going back and looking at your work and just keep saying
WOW, What a great job!
Bill in Pgh, PA
/ Cab in progress
The black canvas came off of a rail road car, they call it a airbag. I got a leaker and used both sides of it, it is about 1/6" rubber. cuts easy, but strong. If needed I can try to get more.
Lets see- Plans umm. I did not have any, I just started and dreamed alot (day & night ).
Thanks I am very proud of it.
I took the back off and put the hoe on after work. plenty of room
/ Cab in progress #44
Great job on your cab. You went to a lot more expense than I did on mine. If you didn't read one of my prev. posts, I stated that Northern Tool has a cab heater that connects to the engine just like a cars heater hoses do.
/ Cab in progress #45
EXCELLENT! You just gave me another idea. Too bad I got more ideas than money.
/ Cab in progress #47
Great looking cab. Well done and thoiught out. Question; How is it secured to the tractor?
/ Cab in progress #48
Makes me wish I had one. It's 12 degrees out.....
/ Cab in progress #49
Great job! Mcfly and I are going to try one this spring, and yours is really encouraging (even if it IS green:D ).
Question for you - did you get tempered glass all round, and if so, how do they cut the shapes? You can't cut tempered, can you? Also, is the glue-on method all you used (no screws, retainers, etc.), and how is it holding up?
On the heater thing .... my wife's suburban has heated buckets ....... ??
Whaddaya think the penalty'd be for that?;)
/ Cab in progress #50
glass ....
plexyglass? ploycarbiate? or regular DS safty glass?
btw do you have a rhino FEL?
/ Cab in progress #51
i personaly would go with what is called tractor glass my father owns a skid steer and he tried plexiglass it cracks in winter and it attracts alot of dust. tractor glass spiders but wont break. my fathers skid steer has runn two years with a hole in on of the windows that he made. a cut off tree limb went through the side stopping just short of his head. all we had to do was just lightly push the glass back in place and it has stayed in place ever since.
thats what i suggest really neat glass it has layers of plastic integrated into the glass to keep it from completly shattering.
/ Cab in progress #52
I bet if you had painted the top black, you wouldn't need a heater. Maybe mount solar hot water collector on roof, with fan motor inside to blow hot air into cab thru a vent in top.
/ Cab in progress #53
that would work well if you didn't have minus figures here in canada it would do bubkis because we get minus fourty regularly especialy in january.
Skid Steer Flail Mower (A65640)
Skid Steer Flail...
2022 EZ-GO ELITE...
2011 Ford F150 (A66408)
2011 Ford F150...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
