BX25D and UnderArmor
   / BX25D and UnderArmor #21
That doesn't sound right. Are you sure you used the correct mounting hole for the bolt? Here is an under armor installation video. Might be worth double checking. Mine U-A rides high and tight.
It should be the correct holes. I read the manual and then looked at another Youtuber and my front brackets were in the same location. Rears can only go in onle place IIRC.
   / BX25D and UnderArmor #22
Only other thing I can think of is that your rear bracket is not lifting up as high as it should. The first time I raised mine, it actually went up so far it got stuck. I had to jiggle things a bit to get it to release. I don't have a MMM, but did you set the height knob to "TOP" position when you installed the UA?
   / BX25D and UnderArmor #23
Yes. However, I had to adjust the bolt behind the wheel just as mentioned in the manual. I just had to turn it more times than they mentioned.
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
