BX25 Brake Conversion?
/ BX25 Brake Conversion? #1
RAECOREP
Ramsey,MN
kubota BX25
Anyone try a left side brake pedal conversion yet? I am going to try it when winter is done. It would be fairly easy if not for BH sub-frame being in the way.
It looks like just the pedal shaft could be cut and new pedal added on same shaft as original.
I will leave the original pedal and just add new on left but not as tall, basically mirror of right side. I think the hardest part will be getting hole in floor correct. Any thoughts on doing this?
Thank you, I already have the mechanical drawings from Kubota. I am going to check price/availability of pedal assy. probably the easiest way to do it, but not as much fun
/ BX25 Brake Conversion? #5
Has anyone tried to make a 2 pedal HST conversion in place of the toe and heel single pedal?
25D has the brake pedal on left side, much easier to use 2 feet than 1 when it comes to "power inching" as I like to call it. There are a few other things that have been improved too. Most of them can be done with aftermarket parts/add-ons to the 25.
Personally I like the single better. I've run forklifts both ways and a single toe-heel seems to agree with me better.
Swict QA 66" Bucket (A64912)
Swict QA 66"...
2022 Landmaster L7X (A64912)
2022 Landmaster...
2018 Bigfoot Equipment Trailer (A64911)
2018 Bigfoot...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
AGT SDA-140T (A64912)
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
