BX25 Brake Conversion?
/ BX25 Brake Conversion? #1
RAECOREP
Ramsey,MN
kubota BX25
Anyone try a left side brake pedal conversion yet? I am going to try it when winter is done. It would be fairly easy if not for BH sub-frame being in the way.
It looks like just the pedal shaft could be cut and new pedal added on same shaft as original.
I will leave the original pedal and just add new on left but not as tall, basically mirror of right side. I think the hardest part will be getting hole in floor correct. Any thoughts on doing this?
Thank you, I already have the mechanical drawings from Kubota. I am going to check price/availability of pedal assy. probably the easiest way to do it, but not as much fun
/ BX25 Brake Conversion? #5
Has anyone tried to make a 2 pedal HST conversion in place of the toe and heel single pedal?
25D has the brake pedal on left side, much easier to use 2 feet than 1 when it comes to "power inching" as I like to call it. There are a few other things that have been improved too. Most of them can be done with aftermarket parts/add-ons to the 25.
Personally I like the single better. I've run forklifts both ways and a single toe-heel seems to agree with me better.
70" Padfoot Shell Kit (A68134)
70" Padfoot Shell...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
Trump 2028 Metal Decorative Sign (A66738)
Trump 2028 Metal...
2021 TAKEUCHI TB240 EXCAVATOR (A65056)
2021 TAKEUCHI...
ACETYLENE AND OXYGEN BOTTLE (A68842)
ACETYLENE AND...
