BX24 Battery
/ BX24 Battery #1
cubowner
Kubota BX24
I need to replace my BX24 battery. Does anybody know what generic battery will replace / fit the BX24 tractor?
/ BX24 Battery
Will try that thanks
/ BX24 Battery #4
On my 2004 BX2200 standard "24DC" Marine Deep Cycle battery fits in rack perfectly and has the correct post configuration. I assume Kubota has maintianed similar standard in newer BX. Costco (Kirkland) has best $ deal and best CCA in class at 700. Does manual show the spec?
/ BX24 Battery #5
Nope, my neighbor has a BX2200 and his battery compartment is much more forgiving on the size requirements. I'm not sure when they changed it but my BX2350 (assume the same for the BX24) has a very restrictive battery compartment and you can't barely go much bigger than the factory size which is a shame.
I just replaced mine w/ a group 26R battery from the auto parts store. Only difference was the + and - terminals were flip flopped but I was still able to make the connections.
BX2200 battery compartment;
attachment.php
BX24 (same as BX2350) battery compartment;
/ BX24 Battery #6
Hmmm, I would have thought that a deep-cycle battery was the opposite of what's required for the high-current, short-duration load to start a diesel engine.
I presume it's working OK. Did you choose it for the size only, or am i off base here? (again...)
[edit] Just checked my BX-24. A 24DC battery is much larger than the battery in my tractor. Wouldn't fit.
My battery is 8"L, 6.5"W, and 7"H.
Thanks,
Z.
/ BX24 Battery #7
I replaced the battery in my BX24 last week. I went to Costco and the closest one was about 1" longer and 1" taller. The width was about the same. It fits into the space and works just fine.
/ BX24 Battery #8
Use the numbers/letters on the current battery to cross-reference. Also, you may want to check the local battery shops in you're area (not stores like pep boys) most give competitive prices and money off for turning in the old battery.
/ BX24 Battery #9
Really? I had to get a new battery for my Expedition this fall and (O'Reilly auto) charged me $5 or $7 for a disposal fee. Crap!
/ BX24 Battery #10
/ BX24 Battery #11
That's what I mean, it's an auto store and not a battery shop. I realize everyone may not have this type of store within a reasonable driving distance.
/ BX24 Battery #13
The receipt shows +$9 and -$9 so I would say there is no core charge. I guess they put it on the receipt to show you they are not charging you.
/ BX24 Battery #16
If you take your old battery back you will get your money back.
But if you bring in an old battery in trade in the first place, shouldn't it be a swap already? I can't imagine why I would ever bring the battery back to them since I still need one in the truck.
/ BX24 Battery #17
Yes, if you took your old battery in with you then they should have gave you a credit for the core charge.
/ BX24 Battery #18
So maybe it was a disposal fee and he just said core. :confused3: I think that was the original battery and it went 10 years. If I can get that outta this one, I won't sweat it much. :)
/ BX24 Battery #19
If its a "fee", its a charge.
If its a "core charge", its a deposit; you're entitled to you're money back with the return of the core.
Simple as that.
I'd be amazed if they actually charge a fee, because the price of lead is so high, the core has a lot of value. By requiring the return of the core, it helps keeps prices competitive.
Also, I believe many states actually require vendors to charge the deposit. That's so that people are inclined to return the battery for recycling, and not leave boxes of lead & acid on roadsides or parking lots.
/ BX24 Battery #20
I was watching one of those how it's done shows about lead. They said 95% of batteries are recycled but only 50% of aluminum cans. So the battery recycling works pretty good.
207272 (A52708)
207272 (A52708)
golf cart (A56859)
golf cart (A56859)
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
207271 (A52708)
207271 (A52708)
2011 CM TRAILER (A60736)
2011 CM TRAILER...
