BX24 Battery
/ BX24 Battery #1
cubowner
Kubota BX24
I need to replace my BX24 battery. Does anybody know what generic battery will replace / fit the BX24 tractor?
/ BX24 Battery
Will try that thanks
/ BX24 Battery #4
On my 2004 BX2200 standard "24DC" Marine Deep Cycle battery fits in rack perfectly and has the correct post configuration. I assume Kubota has maintianed similar standard in newer BX. Costco (Kirkland) has best $ deal and best CCA in class at 700. Does manual show the spec?
/ BX24 Battery #5
Nope, my neighbor has a BX2200 and his battery compartment is much more forgiving on the size requirements. I'm not sure when they changed it but my BX2350 (assume the same for the BX24) has a very restrictive battery compartment and you can't barely go much bigger than the factory size which is a shame.
I just replaced mine w/ a group 26R battery from the auto parts store. Only difference was the + and - terminals were flip flopped but I was still able to make the connections.
BX2200 battery compartment;
attachment.php
BX24 (same as BX2350) battery compartment;
/ BX24 Battery #6
Hmmm, I would have thought that a deep-cycle battery was the opposite of what's required for the high-current, short-duration load to start a diesel engine.
I presume it's working OK. Did you choose it for the size only, or am i off base here? (again...)
[edit] Just checked my BX-24. A 24DC battery is much larger than the battery in my tractor. Wouldn't fit.
My battery is 8"L, 6.5"W, and 7"H.
Thanks,
Z.
/ BX24 Battery #7
I replaced the battery in my BX24 last week. I went to Costco and the closest one was about 1" longer and 1" taller. The width was about the same. It fits into the space and works just fine.
/ BX24 Battery #8
Use the numbers/letters on the current battery to cross-reference. Also, you may want to check the local battery shops in you're area (not stores like pep boys) most give competitive prices and money off for turning in the old battery.
/ BX24 Battery #9
Really? I had to get a new battery for my Expedition this fall and (O'Reilly auto) charged me $5 or $7 for a disposal fee. Crap!
/ BX24 Battery #10
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
2021 Bobcat T66 (A60462)
2021 Bobcat T66...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
