BX24 Battery
/ BX24 Battery #1
cubowner
Kubota BX24
I need to replace my BX24 battery. Does anybody know what generic battery will replace / fit the BX24 tractor?
/ BX24 Battery
Will try that thanks
/ BX24 Battery #4
On my 2004 BX2200 standard "24DC" Marine Deep Cycle battery fits in rack perfectly and has the correct post configuration. I assume Kubota has maintianed similar standard in newer BX. Costco (Kirkland) has best $ deal and best CCA in class at 700. Does manual show the spec?
/ BX24 Battery #5
Nope, my neighbor has a BX2200 and his battery compartment is much more forgiving on the size requirements. I'm not sure when they changed it but my BX2350 (assume the same for the BX24) has a very restrictive battery compartment and you can't barely go much bigger than the factory size which is a shame.
I just replaced mine w/ a group 26R battery from the auto parts store. Only difference was the + and - terminals were flip flopped but I was still able to make the connections.
BX2200 battery compartment;
attachment.php
BX24 (same as BX2350) battery compartment;
/ BX24 Battery #6
Hmmm, I would have thought that a deep-cycle battery was the opposite of what's required for the high-current, short-duration load to start a diesel engine.
I presume it's working OK. Did you choose it for the size only, or am i off base here? (again...)
[edit] Just checked my BX-24. A 24DC battery is much larger than the battery in my tractor. Wouldn't fit.
My battery is 8"L, 6.5"W, and 7"H.
Thanks,
Z.
/ BX24 Battery #7
I replaced the battery in my BX24 last week. I went to Costco and the closest one was about 1" longer and 1" taller. The width was about the same. It fits into the space and works just fine.
/ BX24 Battery #8
Use the numbers/letters on the current battery to cross-reference. Also, you may want to check the local battery shops in you're area (not stores like pep boys) most give competitive prices and money off for turning in the old battery.
/ BX24 Battery #9
Really? I had to get a new battery for my Expedition this fall and (O'Reilly auto) charged me $5 or $7 for a disposal fee. Crap!
/ BX24 Battery #10
/ BX24 Battery #11
That's what I mean, it's an auto store and not a battery shop. I realize everyone may not have this type of store within a reasonable driving distance.
/ BX24 Battery #13
The receipt shows +$9 and -$9 so I would say there is no core charge. I guess they put it on the receipt to show you they are not charging you.
/ BX24 Battery #16
If you take your old battery back you will get your money back.
But if you bring in an old battery in trade in the first place, shouldn't it be a swap already? I can't imagine why I would ever bring the battery back to them since I still need one in the truck.
/ BX24 Battery #17
Yes, if you took your old battery in with you then they should have gave you a credit for the core charge.
/ BX24 Battery #18
So maybe it was a disposal fee and he just said core. :confused3: I think that was the original battery and it went 10 years. If I can get that outta this one, I won't sweat it much. :)
/ BX24 Battery #19
If its a "fee", its a charge.
If its a "core charge", its a deposit; you're entitled to you're money back with the return of the core.
Simple as that.
I'd be amazed if they actually charge a fee, because the price of lead is so high, the core has a lot of value. By requiring the return of the core, it helps keeps prices competitive.
Also, I believe many states actually require vendors to charge the deposit. That's so that people are inclined to return the battery for recycling, and not leave boxes of lead & acid on roadsides or parking lots.
/ BX24 Battery #20
I was watching one of those how it's done shows about lead. They said 95% of batteries are recycled but only 50% of aluminum cans. So the battery recycling works pretty good.
1660 (A59213)
1660 (A59213)
207283 (A52708)
207283 (A52708)
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
2015 CHEVROLET SILVERADO (A60736)
2015 CHEVROLET...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2008 Kenworth W900 Grapple/Storm Truck, VIN # 1NKWX40X68J221827 (A61165)
2008 Kenworth W900...
