BX2350 - Three Point Log Splitters
   / BX2350 - Three Point Log Splitters #11
crossfire190 said:
I have searched and have read all the pros and cons of using a Three Point Log Splitter in general.
I was wondering if anyone with a BX2350 (or similar tractor) has a Three Point Splitter. If so, what brand/style splitter? What is your setup? Do you have it plumbed to the Loader valve, if so how? Or do you have a separate block? What are your cycle times? Any problem splitting any wood? Would you recommend the setup or recommend an alternative and why?
The BX2350 has a 6.3 GPM Pump.
I had a BX 22 with a 3 point splitter, I ran it off the backhoe lines, about 3/4 throttle and it split just fine. In about a hour I had more wood than I wanted to stack. And to this day I have not had to put fuel in the splitter or worry about the gas messing up the carb whin not in use.
   / BX2350 - Three Point Log Splitters #12
I have a Ramsplitter 3-point splitter for my BX24 and love it. I run it off the backhoe lines and it works fine. I can run the tractor at about 2200 rpm and the cycle time is just right for me.
I have enought time while it is returning to throw the split pieces on the pile and get another round ready. Like others have said, it keeps me working at a steady pace that doesn't tire me out.
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2016 Volvo Semi (A59814)
2016 Volvo Semi...
John Deere StarFire 6000 (A59814)
John Deere...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
207278 (A52708)
207278 (A52708)
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
