BX2350 front weight question
/ BX2350 front weight question #1
Mathias NY
Williamson, NY
Kubota M7060, Kubota BX 2350, Case DO, Case DC, John Deere B, John Deere H
Does anyone have an idea on how much weight I would need to add to the front of the tractor to take the place of the loader? I have a weight bracket and 320 lbs of suitcase weights, but I'm worried this won't be enough.
I'm using the tractor on flat ground with a snowblower on the 3pt. The empty loader is more than enough weight to keep the front tires on the ground at all times.
Thanks for looking!
/ BX2350 front weight question #2
Assuming your blower is reasonably matched to the tractor size, I doubt you will even need the 320 lbs that you currently have.
A belated thank you for the replies!
I was very surprised when I took the loader off. The front end stays on the ground without any weights... as long as I'm on level ground and am not changing directions.
4 weights was plenty of weight to keep the front end down with my conditions.
/ BX2350 front weight question #5
I want to buy a lift for the front end of my BX2350. Can someone tell me what the weight of the front end is??
Thanks
/ BX2350 front weight question #6
An educated guess would be about 650 lbs, no loader or weights.
/ BX2350 front weight question #7
When I hang a 5' brush cutter on the back of my bx2200 with the 3 pt in the up position, I can lift the front of the tractor off the ground with one hand w/o the loader attached.
2018 BOBCAT S470 SKID STEER (A62129)
2018 BOBCAT S470...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2017 Forest River Travel Trailer (A61569)
2017 Forest River...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK02CK16471 (A61165)
2002 Freightliner...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
