BX2350 front weight question
/ BX2350 front weight question #1
Mathias NY
Williamson, NY
Kubota M7060, Kubota BX 2350, Case DO, Case DC, John Deere B, John Deere H
Does anyone have an idea on how much weight I would need to add to the front of the tractor to take the place of the loader? I have a weight bracket and 320 lbs of suitcase weights, but I'm worried this won't be enough.
I'm using the tractor on flat ground with a snowblower on the 3pt. The empty loader is more than enough weight to keep the front tires on the ground at all times.
Thanks for looking!
/ BX2350 front weight question #2
Assuming your blower is reasonably matched to the tractor size, I doubt you will even need the 320 lbs that you currently have.
A belated thank you for the replies!
I was very surprised when I took the loader off. The front end stays on the ground without any weights... as long as I'm on level ground and am not changing directions.
4 weights was plenty of weight to keep the front end down with my conditions.
/ BX2350 front weight question #5
I want to buy a lift for the front end of my BX2350. Can someone tell me what the weight of the front end is??
Thanks
/ BX2350 front weight question #6
An educated guess would be about 650 lbs, no loader or weights.
/ BX2350 front weight question #7
When I hang a 5' brush cutter on the back of my bx2200 with the 3 pt in the up position, I can lift the front of the tractor off the ground with one hand w/o the loader attached.
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
2018 Ford Expedition MAX Multipurpose Vehicle (MPV), VIN # 1FMJK1KTXJEA37391 (A61165)
2018 Ford...
